Octura vs CNC prop
  • Yakoo
    • Apr 2019
    • 36
    Octura vs CNC prop
    [B/]octura for high performance or CNC[/B]
  • NativePaul
    Greased Weasel
    • 2764
    What sort of high performance, do you want high efficiency or flat out high speed?
    For the Endurance racing that I do low blade area CNC prop series from Dr Props, Tenshock and TP are signifantly more efficient than a stock BSP Octura, and you have to do some significant thinning and reshaping of the Octura blades to get that back. To take that to an extreme the Graupner carbon props are the most efficient props available and while they are very fragile they give more performance per watt than any metal prop possibly can.
    On the other hand the CNC props we race with and even the modded Octura props I race with will fold up like a flower if I use them with SAWs power levels. Octura, ABC and Prather cast props with near stock thickness are much stronger and thus will be capable of handling more power and thus reaching higher speeds.
    The one exception to that is Dr Prop, who CNCs his props from stainless steel not aluminium alloy, his NAMBA range are much thicker than his Naviga range and can handle some serious power.
    • Yakoo
      • Apr 2019
      • 36
      want high speed, Setup tp4070/1090 KV 10sx2
      • StevenBryant
        • Nov 2012
        • 359
        Speak to Chris Hoffman he will sort you out with the props you need
        Sent from my iPad using Tapatalk
        • sonsone
          • May 2019
          • 3
          Not necessarily
          • sonsone
            • May 2019
            • 3
            How do I reach Dr. Prop?
            • StevenBryant
              • Nov 2012
              • 359
              Go on face book and search Alex Prop and you’ll get his details
              • sonsone
                • May 2019
                • 3
                StevenBryant..
                Thank you.
                Sonsone
                • NativePaul
                  Greased Weasel
                  • 2764
                  Or his other contact details are on his website
                  http://doctorprops.torgg.com/
                  • Mr Zelos
                    • Oct 2019
                    • 14
                    Alex is one cool dude
