Prop bore diameter !
  • Speedfreek
    • Apr 2018
    • 276
    Jay already told you no The hub would be to thin I don't suggest it at all what prop anyway ?
    Thanks , X57
    MYSTIC 138 119 MPH so far
    • Speedfreek
      • Apr 2018
      • 276
      Originally posted by larryrose11 View Post
      Using a 1/4 drive dog is a brilliant idea.
      This puts all the stress on the outer diameter, and is not transferred through the step down.
      I can't say for sure, but I'm willing to bet that the step down has a square corners at the step, which will lead to stress concentrations.
      Going with the 1/4 drive dog eliminates all of that. That would be a much more robust setup.
      Exactly, thanks.
      • Speedfreek
        • Apr 2018
        • 276
        Originally posted by Bp9145 View Post
        After all the advice from very experienced people, those who have tried and also from dasboata, the prop guru, it's not advisable to do it. . . then perhaps he needs to find out for himself and go ahead and do it. . .Maybe he will be successful and we can all learn something new!. . .It's like telling a driver not to go through a red light as you might get caught and get a ticket . . .even worse get into an accident. So the driver does it a couple of times and gets away with it, finally on the third time he goes through the red light he gets hit by another car. . .the results are devastating, not just a ticket but perhaps lives lost. I apologize for the very harsh analogy but same principle.. .take the advice and save yourself the trouble. I too have tried it with no success as I ruined the prop before I could even put it on and break it during use. ..
        Thanks ,but I needed to here it from a prop guy
          • 7651
          I’ve been running like this for a number of years. I have not broke a shaft. I have run cut down 457’s on this setup and mangled a couple props due to debris in the water. No broken shafts.
          • dasboata
            • Dec 2010
            • 3152
            Hey I have a ABC 1/4" shaft 3 blade very similar specs if your interested
            • Speedfreek
              • Apr 2018
              • 276
              Sweet
              • Speedfreek
                • Apr 2018
                • 276
                Not a real fan of 3 blades , I have a Mystic 138 so would need a set of CR .....
                Do you have em in a two blade CR 1/4 ?
                • dasboata
                  • Dec 2010
                  • 3152
                  Ok I like 2 blades on cats anyway !!!
                  • Speedfreek
                    • Apr 2018
                    • 276
                    What can you recommend in a two blade in a 1/4 Shaft ABC, and a little more aggressive then a Octura X57 ?
                    Need CR too !
                    • dasboata
                      • Dec 2010
                      • 3152
                      Need CR too !
                      Ask your prop guy ????
                      • dasboata
                        • Dec 2010
                        • 3152
                        [QUOTE=Speedfreek;733986]What can you recommend in a two blade in a 1/4 Shaft ABC, and a little more aggressive then a Octura X57 ?
                        Need CR too !
                        [/Q 2214 2215 ish
                        • Speedfreek
                          • Apr 2018
                          • 276
                          [QUOTE=dasboata;733996]
                          Need CR too !
                          [/Q 2214 2215 ish
                          I don't know the specs on ABC props I don't have a chart on them my ESC was Luke warm with a X57 108 mph !
                          • Speedfreek
                            • Apr 2018
                            • 276
                            If you just have to use 1/4” cable, get one with a steped-down stub shaft. I would NOT drill out a prop, especially for high rpm SAW-type running.
                            https://www.offshoreelectrics.com/pr...?prod=ose-1290
                            Here is the problem with the OSE shaft for me, mine is 5 1/2 inch before the flex OSE one is 4 inch.
                            It will not work with my drives
                            Mine , my bearings are at about 2 and 5 and it's 8mm thick shaft.
                            OSE , 3/16 to 1/4
