Large V Hull Prop ideas
  • bobby89
    • Apr 2012
    • 56
    I am looking for some recommendations on props. Here is what I am building:
    CRC 58" fountain
    Leopard 5692 730kv motor
    300-400 amp ESC (brand yet to be determined)
    12s Battery (2 6s series, 5000-6000MAH)
    Please let me know what you think would be a good starting point. Looking for a good balance of speed and run time.
  • MarkF
    dinogylipos.com
    • Mar 2008
    • 988
    That motor is way to small for that size boat. On 12s I would start with a 455 and that is only a 3/16 size prop. Not good for a 58" boat.
    If your interested I have a large TP motor I ran in my 45" boat on 10s and a 7016 3 gas size prop.
    • Jesse J
      scale FE enthusiast
      • 7818
      That boat needs two of those leopard motors and my two arrow shark out drives, then it would reach full awesomeness!!
      "Look good doin' it"
      See the fleet
      • bobby89
        • Apr 2012
        • 56
        Motor should be fine in this boat and on 12s. Its rated for a max of 50v I believe. I have a few others Ive seen of this exact boat on 12s with a 5670 TP motor. Just looking for a good prop to start with.
        • MarkF
          dinogylipos.com
          • Mar 2008
          • 988
          Yea and that TP motor is a bigger stronger 6 pole motor. I run that motor in my 45" race boat and a 7016 prop. The 5692 is a smaller 4 pole motor and would be better suited for a 36 to 40" mono. That motor would swing a 455 prop and that's not going to push a big and heavy 58" mono very well. But yea it will push it.
          • bobby89
            • Apr 2012
            • 56
            Ok thanks
            • MarkF
              dinogylipos.com
              • Mar 2008
              • 988
              For that size hull I would use the beast motor OSE sells here, and ask Steven to send it to his guy to make a water jacket for it. This motor would probably swing a 7214 size prop which would push this big boat very nice. I think that would be the best solution for this size of hull. I have been converting big hulls for over 10 years and I think this would be an awesome set up for your boat. I hope this helps.
              Mark
              • justski
                • 254
                Hi Mark
                I have a 44 inch Delta Force Sniper ...and I have the beast motor from OSE well its a different brand I bought from OSE like 6 years ago it looks the same ..Its a Toro beast x528 2y 4 poles 780kv and I have a swordfish pro 300A esc hv max 380A...from what I know the motor will only take 38V so I can only run it no higher than 10s ...any hints of what prop to start out with ?...Thanks Jim
                • justski
                  • 254
                  Mark
                  Hi Mark
                  • MarkF
                    dinogylipos.com
                    • Mar 2008
                    • 988
                    I think an octura X467, would be a good place to start. I have the TP 5870 780kv motor and it swings a prop shop 7016 380. An ABC 2614 3 chopper would be another good one as that is a good mono prop. Whatever you try you have to see what gets everything hot or not and go from there. I don't know your motor so the 467 is where I would start to see if your motor can handle it and then go up from there if it can.
                    • Alfa Spirit
                      • 2183
                      CRC 58" fountain
                      You can use a 2 x 5692-730kv setup
                      • justski
                        • 254
                        Thank you Mark I will let you know how it works if we dont get snow again.....LOL
