Prop for Aeromarine Challenger 31
  • rrc1962
    • Dec 2018
    • 3
    Hi Guy's...
    First post here. I'm building the Aeromarine Challenger 31 with OSE's recommended motor (Leopard 4082 1600kv) and a SeaKing 180 V3 ESC. Probably run it on 6S, probably 2 3S packs in series for weight distribution. I'm wondering if anyone has set up something similar and can recommend a prop. I'll buy a few props, but I was hoping to get a good starting point, then buy a few on either side of that. That and some temp reading should land me on the right prop without buying Octura's entire inventory.
    Thanks for any input you guys may have.
    Ross
  • dasboata
    • Dec 2010
    • 3972
    440/3 is a good place to start
    • Panchothedog
      • Oct 2015
      • 173
      Different hull (31" pursuit) but same motor and ESC also running on 6 S and the boat runs real good with a X645 or a X448. Faster with the X448 but it is probably at the limit size wise. Good luck with your project.
      • rrc1962
        • Dec 2018
        • 3
        Thanks guys. I was thinking 2 blade around the 46-48mm range. the 3 blade sounds interesting too though. Gives me starting point.
        • 785boats
          Wet Track Racing
          • 3423
          A 440/3 as dasboata suggested, is my favorite prop for that size boat with those revs. That's for oval racing. Straightline speed will be different. A Prather s220 is a good one to start with. Then maybe a Prather s225 if the temps stay low enough on the s220 after a few passes.
          • StevenBryant
            • Nov 2012
            • 366
            Same setup on a Deltaforce 21 Hull I run m445, m545, and m447 motor and esc are definitely not stressed and could take more prop
            Sent from my iPad using Tapatalk
