hi can some one help me with prop for a 33 inch mono with a neu 1521 1577 kv with castle 240 what is the best abc prop I can use for racing in p mono class
prop
what ever happened to manners best way not to get a answer from me is don't ask please or thank you ! just sayingOriginally posted by rogert View Posthi can some one help me with prop for a 33 inch mono with a neu 1521 1577 kv with castle 240 what is the best abc prop I can use for racing in p mono class
A 1521 -1860kv- 8mm shaft is a better motor for "P" Mono then a 1515 -2200kv.
The 1521- 1860kv can swing a 548 for racing, where you would only be able to swing a 445mm with the 1515 in a mono without getting it too hot.
1515 - 2200kv is a very good "P" Sport Hydro motor.
LarryPast NAMBA- P Mono -1 Mile Race Record holder
About the same as the 1521- But I would suggest one with a 8mm shaft from TP. and a longer cooler from HRC for racing.Originally posted by Speed3 View PostA motor I was thinking about was a tp 4060 1950kv, what's the opinion on this motor.
1C1B2528-5E89-4E31-B0B0-0064E3C5ACA4.jpgYou sir are nobody to talk about manners you are the worst at it. All I did is ask you a question regarding a prop you made for me. And this was your reply.Originally posted by dasboata View Postwhat ever happened to manners best way not to get a answer from me is don't ask please or thank you ! just sayingLast edited by royalcasa; 12-01-2018, 08:28 PM.
