Q Hydro Prop Recommendations
  • Cottageboater
    • 779
    I have an old Aeromarine Shadow hydro that I am building as FE. I already have the two motors listed below and plan to use one of them on this project. Hoping for 60-70mph range. Any recommendation on ABC or Octura props would be appreciated.
    HET 700-98-1170kv
    HET 700–98-1270kv
    I will be using either a Swordfish 8s 200a or 12s 240a ESC. Haven’t made up my mind. Thanks for your help.
  • photohoward1
    • 1629
    X452 start with.
    • Cottageboater
      • 779
      Thanks Howard. Any ABC recommendations?
      • MarkF
        dinogylipos.com
        • Mar 2008
        • 979
        ABC 2215 from Brian B
        Mark
        • rol243
          • Apr 2017
          • 1038
          isn,t 12s abit much for those motor kv sizes ? unless its for SAW. ??
          • Cottageboater
            • 779
            Mark
            Thanks Mark
            • MarkF
              dinogylipos.com
              • Mar 2008
              • 979
              If you go with Brian he will recommend a good prop for your set up. I run 2215 and 6s on a 1520 kv motor in a rigger and my boat is in the 80s. For your kv he may say a 2217 or 2315 will be a good prop.
              Mark
