Prop suggestion Cheetah 4S ovals
    I would like advice on ABC props for a said Cheetah.
    3 blades?? I've seen Ray Presnell run a ABC 3 blade on a boat but, few people talk about them, just 2 blade props.
    1521 1.5D and REvo packs.
    Thank you.
    Ray, I wonder if one of the 15* rake 3’s would cut it. The 10* old standard ABC props have a lot of lift would likely put the nose into the water. The 17* have the opposite effect but the 15* are not as bad in my experience so far.
    Seems to me Tony liked a 50mm prop for a single Cheetah.
    • TRUCKPULL
      • 3293
      Ray
      1521 1.5Y is only 1050 KV, a little low for 4S on a CAT????
      Larry
        Originally posted by TRUCKPULL View Post
        Ray
        Larry
        Sorry Larry it’s a D wind. Lol...
        • TRUCKPULL
          • 3293
          That's better - 1860Kv on 4S
          I have a few 450/3 cut down to 48mm, detounged, backcut, and a bit of tip cup. you can try.
          or a ABC 1915 -17 degree rack 2 blade prop.
          Larry
            Thanks Larry. Going back to my cave tomorrow or Wed. Selling my P-Shooter, lots to do... car repairs again, yada yada...
            • properchopper
              rcgoatbuild@snotmail.com
              • 7708
              Ray, a little late (just bumped into this thread) - If you keep the hull loose/nicely aired out you can run just about any prop - the 1521 1.5D is like a diesel bulldozer motor - mucho grunt. I replaced mine with a somewhat comparable TP Power 4060 (2040KV - sorta close) and have run 450/3 Oct's and for 2-Lap record runs or just for going to "11" the 452/2 without breaking a sweat. I'd give Larry's cut down 450/3's a shot - sounds like a great choice.Keep it loose (no plowing)
              Here's the 2040KV TP Power with a fairly stock 447/3:
                I am fairly used to those props but thank you for chiming in. I was curious about ABC props specifically.
                Just trying to see what I can play with in ABC.
                Major brain fart. Big edit, lol...
                • Moonie
                  • Jan 2014
                  • 343
                  I use a neu 1521 1860kv with a castle 240 hydra ice along with a x452/3 detongue, lil rake and round ears. Works good on cats with that cut minus the rake on some hulls. The strut height ajustment is the single most important thing.
                  Gold Spilo
                  • photohoward1
                    • 1781
                    1916 ABC 17*.....let her rip.....
                      Thanks Howard. I have a 1915 ABC 17* to try until I can get one.
