Sharpening trailing edge
  • jester_s1
    • Jun 2014
    • 82
    When putting the final touches on a prop, I see that having a sharp square corner on the trailing edge is important. My question is do I make that square corner perpendicular to the hub, or should I attempt to make it perpendicular to the prop blade? The latter seems right, but photos I've seen look like the former is standard practice.
  • dasboata
    • Dec 2010
    • 3972
    Square to the prop face
      Yes, Chris is correct (no surprise there).
      • jester_s1
        • Jun 2014
        • 82
        Help me out with what that means. Does that mean that both angles will be the same because I'm squaring it to the plane of rotation perpendicular to the hub, or will the angles be different because I'm squaring each side to the trailing edge angle?
        Sent from my SM-G900P using Tapatalk
        • dasboata
          • Dec 2010
          • 3972
          you sound like a intelligent guy lets not ruin it,, the explanation is quite clear,, unless your a engineer that is going to over think the whole thing
          • jester_s1
            • Jun 2014
            • 82
            I try to be an intelligent guy, but it's not clear to me. What do I square the trailing edges to?
            • dasboata
              • Dec 2010
              • 3972
              to the concave side
              • dasboata
                • Dec 2010
                • 3972
                to the concave side but I doubt anyone would notice the difference if not true !!
                • jester_s1
                  • Jun 2014
                  • 82
                  Ok, last dumb question about this- The angle between the root and tip of the blade is different at the trailing edge. Do the prop gurus make the whole thing match at some point on the prop, or should the angle change from the root to the tip? Or does it really matter either way?
                  • steinersamuel
                    • 480
                    This right here is priceless! I love it!
                    • Bp9145
                      • Jan 2016
                      • 1466
                      Lol!
                      • paulejr
                        • Mar 2023
                        • 162
                        ..bump ...
                        • tbonemcniel
                          • Sep 2020
                          • 294
                          I take offense! But as an engineer even, I just let Chris do my props for me lol
                          • paulejr
                            • Mar 2023
                            • 162
                            Well, as a Machinist ( Maritime) I'd do my own, but at my age I just can't seem to hold it still long enuf to do any good so... off to Chris ...
                              I've been doing my own props for a long time and I still don't understand Chris. I just follow what the factory did for the trailing edge.
                              A diagram would be nice.
