ABC props bending
  • Eric 1
    novice
    • 50
    ABC props bending
    I'm having trouble with several ABC props bending the blades during running.
    I don't know what alloy they are using, does any one know & if they can be heat treated. If so what temp/time.
    Thanks for any assistance.
    Eric.
  • rol243
    • Apr 2017
    • 1038
    what motor rpms are you doing ? are you thinning out the blades too much ? you can,t heat treat properly unless you have the correct kilm etc etc.
    • Eric 1
      novice
      • 50
      Thanks for the reply rol243.
      My props have minimum thinning, motor RPMs in the 33,000 to 35,000 range under load. I have access to heat treating kiln.
      • rol243
        • Apr 2017
        • 1038
        there has also been issues with Octura props busting off blades at high rpm,s. i would give Chris [ Dasboata ] a pm as he would be the guy to get better info from.
        • dmitry100
          • Mar 2015
          • 1264
          you are throwing blades only at 35k RPM ? jeez... makes me wonder what my hardened abc would do at 60k.
          • rol243
            • Apr 2017
            • 1038
            60k ?
            • dmitry100
              • Mar 2015
              • 1264
              63k RPM under load to be exact, yea
              • rol243
                • Apr 2017
                • 1038
                what motor and battery size is giving you those high rpms ?
                • dmitry100
                  • Mar 2015
                  • 1264
                  lehner 1950 on 6s
                  • RaceMechaniX
                    • 3024
                    Yes you can heat treat the ABC props. I don’t have my notes handy but there is a recipe that works.
                    Tyler Garrard
                    NAMBA 639/IMPBA 20525
                    T-Hydro @ 142.94mph former WR
                    • Eric 1
                      novice
                      • 50
                      Hi Tyler, if you could PM some temps & times when you get an opportunity would be greatly appreciated.
                      I've got a lot of these de pitched and hi lift (ie Bent back blades) props that don't work any more and I'm reluctant to spend too much more $ on these props if they can't handle the power.
                      I'm happy with the speeds they produce over the Octura options, but I can't keep them from bending, some are after just 2 or 3 laps.
                      I was trying to keep with standard props rather than modifying them too much.
                      Thanks Eric.
                      • dmitry100
                        • Mar 2015
                        • 1264
                        you can get dasboata sell you some hardened props
                        • Doug Smock
                          • 5359
                          Jim at ABC posted this awhile back.
                          Make sure the prop is clean.
                          Stress relief @340'F for 20 min.
                          Temper @ 400-600'F for 20-60 min.
                          Tempering(aging) time and temp depend on the size and personal preference.
                          Air chill.
                          MODEL BOAT RACER
                          IMPBA President
                          IMPBA 19887L CD
                          NAMBA 1169
                          • Eric 1
                            novice
                            • 50
                            Thanks for the info Doug, sounds like there is a little room for different amounts of hardness.
                            • TRUCKPULL
                              • 3293
                              Air chill.
                              I wonder if this would be the same for Octura Props?
                              Larry
