Heat treating props
  • NativePaul
    Greased Weasel
    • 2770
    Heat treating props
    Hi all, I am wondering if anyone that heat treats their props is solution annealing them before age hardening and if so how much difference does it make from just age hardening, and how do you do it?
    I have bent a few blades backwards in SAWs and want to harden them, but I don't have the facilities to solution anneal them at home, and don't know if there is something that I can knock up fairly cheaply to do it, if I should send them out to a specialist, If it doesn't add that much strength and isn't needed, or even if it would warp the blades of my finished props and must be done before sharpening.
    From http://www.matthey.ch/fileadmin/user...Parts_LMSA.pdf
    The standard age hardening cycle for the high strength casting alloys, both annealed and as cast, is three hours at 625-650°F (320-340°C).
    However, to develop the highest strength for the as cast products, a separate solution anneal should precede the age hardening.
    If solution annealing is required, it is a high temperature soak: 1450°F (790°C) for the high strength alloys and 1650°F (900°C) for the high conductivity alloys. Annealing must be carefully controlled as excess time or temperature may cause grain growth. Solution annealing should be immediately followed by a water quench. As a precaution, large quantities of metal should not be annealed without first conducting a furnace simulation test. Thin sections, such as finewire, require an annealing time of about 3-5 minutes. Fifteen minutes to one hour is required for thin walled tube and small castings. Heavy sections (above about one inch) usually require 1-3 hours. A heat up time of one hour per inch of thickness must be added to the soak time. Because most salts will attack copper beryllium at temperatures in the solution annealing range, solution annealing should not be performed in a salt bath. When peak aging copper beryllium castings and weldments, the customer must always solution anneal prior to age hardening. However, if peak properties are not required, castings can be age hardened from the as cast condition without the solution anneal.
  • longballlumber
    • 3417
    Not sure if you have an account on www.intlwaters.com, but lots of good info in this thread...
    Did a bunch of research on prop hardening. Bought a Kiln. Got two questions yet for the experts. Is there any preparations to do to the prop before putting in the Kiln? Such as cleaning and or oiling? What cleaner? What oil if any? And - how should the props be set in the Kiln? Just set...
      Be very careful, the exact alloy of the prop MATTERS. For example, ABC props need a different treatment than Octuras. And while the very high temps can harden blades they will also make them brittle. A couple years ago I watched a couple SAW racers throw blades almost every pass due to excess hardness.
      Bottom line, don't believe everything you read on the Internet.
      • dasboata
        • Dec 2010
        • 3972
        This is very true I soak my octura for 3 hours,, and my ABC for up to 1.5 hours depending on there size I got the ABC formula directly from Jim at ABC
        • NativePaul
          Greased Weasel
          • 2770
          At what temp, or temps if they are different. Most of my props are Octura, but I have a few ABC too.
          Do you soloution anneal first, or just age harden?
          • dasboata
            • Dec 2010
            • 3972
            I don't anneal 1st as a habit,,, but I have... ABC's get a pre soak for 20 min at a lower temp 340* and bake at 640*
