I like and prefer 3 blades on a mono you will find they tend to handle better with better accelartion
prop and motor setup
Sizing and amp draw are your concerns here, for starters the CR 447's are good. Easy to sale off if you move past them. Especially if you get Chris to detounge and sharpen/balance them.Originally posted by rad35 View Postanother question is there an advantage to running 3 blade prop vs 2 and lift vs no low lift (x vs m) style. for my app.
You will be able to easily move up to 10s too at a later date with that Kv
I will start with that who is chris? on sharpening props. is my other option to go to bigger motors to run bigger props or not an option. the stuffing tubes are right on the bottom of the hull where they enter the back now sothe only way i can lower them is stinger angle i have 1/4 in. flex cables.
LOL That's me the prop guy!Originally posted by rad35 View PostI will start with that who is chris? on sharpening props. is my other option to go to bigger motors to run bigger props or not an option. the stuffing tubes are right on the bottom of the hull where they enter the back now sothe only way i can lower them is stinger angle i have 1/4 in. flex cables.
chris how do i get in touch with you about doing props? So i go with 447 props 3 blade like chris suggested ( L & R ) tp 4060 1050 5y kv 8's 240 amp esc's. should be a good starting point?
it's been a process but i think we have it. Thank's everyone for the help and bearing with me on this. my next hull will be nothing installed when i get it LOL.
Octura has not made the 447/3 in a few years,,, you can not get them, I do have some prop shop sets of 4714/3 in ss,, that are just about the same size, or can go up to 450/3 octuras and cut them or reduce them down a bit ,,you can touch base with me threw PMs or email me at dasboata@aol.com thanks ChrisOriginally posted by rad35 View Postchris how do i get in touch with you about doing props? So i go with 447 props 3 blade like chris suggested ( L & R ) tp 4060 1050 5y kv 8's 240 amp esc's. should be a good starting point?
That should be a solid setup rad35. PropShops are good(I have a set) but you can just go Octura two blades as well. A three blade does draw more amps due to the extra blade. My preference and I'm sure Chris will agree is three blades on a single as it seems to even out the thrust.
Defiantly on a mono !!!!Originally posted by srislash View PostThat should be a solid setup rad35. PropShops are good(I have a set) but you can just go Octura two blades as well. A three blade does draw more amps due to the extra blade. My preference and I'm sure Chris will agree is three blades on a single as it seems to even out the thrust.
