How do you change props without losing a digit?
    • 4340
    Admittedly a newcomer to FE, so throw me a bone. How are people holding the prop shaft and or prop in place when tightening or loosening the prop lock nut? The set screws in the drive dog don't seem to offer enough torque, holding the motor coupler seems like a bad idea, and I can barely hold the stock prop with my fingers without causing damage to myself so I can only imagine a sharpened prop makes that method even more dangerous.
    I'm guessing there's something easy that I'm missing. Ideas?
  • 785boats
    Wet Track Racing
    • 3423
    Just throw a thick rag over the prop & hold it. Just make sure that it is engaged on the drive dog while tightening or loosening the nut.
    As you are a newcomer, I will add this.
    Make sure the batteries are disconnected first. If for some reason the motor does fire up you could lose more than one digit.
    • boredom.is.me
      • Jun 2009
      • 626
      I hold the motor side of the coupler. ALWAYS DISCONNECT THE BATTERIES!!!
        Leather chamois or 1/16" rubber mat I have.
        • dasboata
          • Dec 2010
          • 3972
          Sorry not a good idea,,, you can screw up the flex shaft,, doing it this way,, the only way is with a rag or a glove !!
          • T.S.Davis
            • 6266
            If the nut is super snug I'll grab the drive dog with small pair of channel locks. Most of the time though I can grip the prop in such a way that I don't shred myself to bits. Cut myself really bad that way before. It's not the smartest thing to do. A rag is the easiest safest I would think.
            Noisy person
            • photohoward1
              • 1781
              Gloves?
              • dasboata
                • Dec 2010
                • 3972
                Originally posted by photohoward1 View Post
                Gloves?
                Yes leather gloves
                • T.S.Davis
                  • 6266
                  Even just those cheesy work gloves from the Depot would be better than what most of us do. I'm going to throw those in my box when I get home. Thanks for being smarter than me guys.
                  Noisy person
                  • boredom.is.me
                    • Jun 2009
                    • 626
                    Ok then my question is, how tight do you guys set the nut? I only have my tight enough to prevent the prop from wobbling. The shaft doesn't even twist when I release. This is using the prevailing torque (all metal) lock nuts.
                    • T.S.Davis
                      • 6266
                      The tension on the nuts vary. I have some I can spin down with almost no effort but some are so tight I can barely turn them even with the channel locks on the drive dog. They're pretty inconsistent.
                      Noisy person
                        • 7512
                        Get someone else to change the prop for you!
                          • 4340
                          Thanks Yoda!
                          I think a pair of cheap mechanics gloves are the next addition to the boat tool box. I appreciate the input fellas.
                          • dasboata
                            • Dec 2010
                            • 3972
                            its a lot how you hold the prop,,, with much care and common sense,,,( I know whats that anymore ? ) a paper towel will work !!
                              Depending on the lane you hold going into the first turn.
