Prop Help
  • dtacmed
    • Mar 2008
    • 215
    Prop Help
    I just installed a Leopard 4082 1600 in a Pursuit. I have X 442, X445,X645 and a M445 props. I'm trying to learn props which of these would be the best starting prop and the main differences in these. Thanks any information is greatly appreciated.
  • 785boats
    Wet Track Racing
    • 3423
    Hard to say without knowing what voltage you intend to run. 4s? 5s? 6s?
    Also, what make & size ESC would be helpful.
    • dtacmed
      • Mar 2008
      • 215
      Sorry meant to add that info 6s 150-6-20 150A Opto Navy Competition Brushless ESC with Capacitor Bank
      • Peter A
        • 1622
        Easy, start with the 442, run, time your runs, check temps etc, go up one size at a time. You will only find the best prop for your setup by testing. It also depends whether you will be racing, sport running or zoom zoom. A 150A esc is not real big if you are after speed.
        • 785boats
          Wet Track Racing
          • 3423
          As Pete says. Start with the 442.
          When you have it all trimmed out & running well on that, the 445 will be the next to try. It will be a shorter run time though.
          Another great prop on that boat with those revs if you are running oval laps it the X440/3 blade.
          • dtacmed
            • Mar 2008
            • 215
            What about the M 445 and the X 645 how or would they play in on this set up ?
            • 785boats
              Wet Track Racing
              • 3423
              For sure you can try them all.
              Just watch the temps & run times. Check every minute. while dialing in the boat.
