32" Deep V Prop Help
  • distortion10
    • Apr 2012
    • 10
    Hello,
    Just finished rebuilding my dad's old rc boat and I am having an issue with prop selection. Here are the specs:
    32" deep v (All original running hardware is being used circa 1982)
    Leopard 1800kv BL
    Seaking 180 Amp V3 ESC
    4S Lipo
    After rebuilding and painting my first few runs have been with an Octura 1250 prop the boat was using when it was a nitro. Up to half throttle it gets on plane and runs well but starting at half and up to 3/4 throttle it cavitates some then runs fine then cavitates some, but anything 3/4 to full is full cavitation. Tried a Octura 1255 but that cavitated worse and at lower rpm. I have an octura 1240 I'm going to try later today but it just looks to small....course I am just getting into boats so I really don't know what is correct.
    With the 1250 prop I can run for about 5 minutes and the motor and esc are worm to the touch but not even close to hot. Was thinking I need to try an Octura x4 prop or x6 but not sure where to start diameter wise? Any advice is greatly appreciated.
    Your problems are likely the use of the wrong type prop. The 1200 and 1400 series Octuras are lifting props and are not the best for your boat. An x450 or x455 should work much better but are costly and need sharpening and balancing. These props are much less costly but should work better than what you have.
    http://www.offshoreelectrics.com/pro...od=grp-2317.51
    http://www.offshoreelectrics.com/pro...od=grp-2317.54
    Whatever you use keep a close eye on temps.
    • distortion10
      • Apr 2012
      • 10
      Glad I was sort of on the right path. I'll go with the cheaper options for testing and get the more expensive option once Ive narrowed it down.
      Thanks again.
      • dasboata
        • Dec 2010
        • 3972
        You should change the boat to surface drive,, as stated the 1200 series will life the transom too much another thing is if you spinn the boat out or flip it once that rudder will bend ! the 3/16 shaft on add does not give it the support it really needs
        • distortion10
          • Apr 2012
          • 10
          Thanks for the advice. The new props I ordered are worlds better.
