Trouble finding smaller 3/16" counter rotating props
  • Tylerfishsmith
    • 10
    Do these exist or am looking for a ghost? Have twin Leopard 2860's/1690KV w/ twin Aquastar 120 esc's and a 4s battery. It has twin surface drives with 3/16" flex shafts. Am thinking I need smaller pitch and diameter to work properly with this oddball set up. Not really looking for high speed here. Any idea's are appreciated.
  • JimClark
    • 5902
    Smallest one I know of I think is a x440 in octura not sure of other prop makers. You might check prop shop
    Sent from my SM-G900T using Tapatalk
    Billy Graham
    • Tylerfishsmith
      • 10
      Thanks for the quick reply. I am finding the same. What is the prop shop?
      • JimClark
        • 5902
        They are in england but I think Dasboata on OSE who balances props orders from them sometimes so maybe he can help you
        Billy Graham
        • 785boats
          Wet Track Racing
          • 3169
          Steve here at OSE has Octura X437/3 blade, & 438/2 blade in the CNC range. both with 3/16" bore.
          • T.S.Davis
            • 6228
            Octura makes a 536 but not in counter rotating.
            Propshop will deliver to the states.
            We supply a large range of model boat propellers. Most propellers are made to order however we do keep a selection of popular scale props.
            Noisy person
            • Tylerfishsmith
              • 10
              Thanks for the replies. I was not sure if the X437/3 may be to much to swing. Thanks again.
              • 785boats
                Wet Track Racing
                • 3169
                You can usually run bigger props on motors in a twin set up than you can on the same motor in a single set up in the same size or even slightly larger boat.
                Also, a couple of strokes with a file to take half a millimeter off the tips & you are down to a 36mm prop if they are drawing too much load.
                But you are only spinning at 25000 revs. Depends on the type & size of boat.
                Any pics?
                • dasboata
                  • Dec 2010
                  • 3152
                  Thanks Jim I am a prop shop dealer but you are probable best off just ordering them from there website http://www.prop-shop.co.uk/index.php?section=home
