props ...... L @ R
  • marko1au
    • Dec 2013
    • 21
    props ...... L @ R
    i have a look around and i cant find any m445 props in R hand ....... is there anyone out there that does stock these or pretty close to ....... i have a twin setup and have resized some x447's to 45 mm but im not confident that they are correct .... i think they are close but would like to try something that is made with hopefully closer tolerances ( or by somebody that has had more experiance than me ) okay ill admit this the first time i have resized props for a twin setup ...... i have done a couple for single ..... with ( well i think some success ) ...... any help would be appreciated thanks in advance
    I would get Chris (Dasboata) to size you some 1814's or some 447's. It is well worth the $$. He does awesome work.
    Outside of that you have CNC available or PropShop UK should have something. http://prop-shop.co.uk/
    Oops I just looked, Nothing in RH45mm
    • marko1au
      • Dec 2013
      • 21
      thankyou srislash ...... after posting this i found the abc prop site and was looking at the 1815-17-45(2) cll and clr props .... im not sure if these will suit ..!!!! i have a set of m442,..... m447 and was looking for something in between
        Those are pretty much the HOT props for the time being. You will need some Neg dialed in with those or some weight in the nose compared to what you have been running. They will likely pull a few less amps too. What is your setup Marko if you don't mind me asking? Motor kv/cells?
        • marko1au
          • Dec 2013
          • 21
          no worries about asking ..... i have the enzo ( i think you guys call it the fightercat) twin sss 4074 2200kv motors, 2x220 s/f esc's with extra caps 6s2p ..... 013.jpg
            Looks good! Well those props done by Chris got me over 100mph with my Fantasm. It was turning an actual 41,000 rpm.
            • dmitry100
              • Mar 2015
              • 1264
              marko: interesting looking drives on that thing... what are they? can you post a more detailed pic of the bottom :)
              • dasboata
                • Dec 2010
                • 3972
                Thanks Shawn !!!! Marko I can come up with something in ABC that will perform just as good if not better then the M445 PM me if interested thanks Chris
                • marko1au
                  • Dec 2013
                  • 21
                    Originally posted by marko1au View Post
                    interesting you say ......... [ATTACH=CONFIG]139497[/ATTACH]
                    Those MTC's mounted 'inverted style' Marko? Good take on the 'what drive fits' issue. How are the pads on that one?
                    • dmitry100
                      • Mar 2015
                      • 1264
                      marko: Where did you buy them? Never seen those before... even MTC doesn't come to mind. hmm..
                      • marko1au
                        • Dec 2013
                        • 21
                        the pads ...... mmmm they look good ... i might have to do some adjustments to them, now that its starting to see some speed im seeing possible issues with the pads ........ early days and ill keep you posted ....
                        • marko1au
                          • Dec 2013
                          • 21
                          im a newby with abbreviations (MTC) ......... if your talking about the bits out the back that hold the flexes, they are tfl struts ..
                          • marko1au
                            • Dec 2013
                            • 21
                            i have to be honest guys the idea of using struts was not mine ............ i bought the hull with the struts and rudder mounted ........ which i thought was a very good idea ( thinking outside the square)
                              It will be good for setup and prop changes Marko. I put struts on my R-42 for this reasoning.
