HK genesis prop help
  • MG1234
    • Jul 2015
    • 638
    Props are so complicated but fun when you get to go fast ,help please ,HK genesis,4092-1750kv,x445 OSE aluminum prop,6s, good temps running hard , I can get some more top end out of this boat but I'm at the end of my learning curve ,can someone suggest a prop that will be my next step up? The lipos are working the hardest and can take a little more load ,,I'm ready to order one ,gotta be balanced and ready to run ,don't care about material,the ABC look great but I need to know the next step up ,they rate their props differently ,thanks,
  • 78MaicoRider
    • Jun 2013
    • 179
    I would try a M545. Thats the same diameter (45mm). However, it has a pitch ratio of 1.5 instead of what you have now 1.4. Also the M series has tounge removed for an easier to turn prop. There is alot of recommendations on props for this hull in past posts. Use the search function and find a wealth of information.
    41" & 29" FE Aeromarine Sprint Cats, Quickdraw powered "Dollar Eater" 41" Insane Cat, 29" BL mod Graupner Cat, 24" Hydro, 29" OB Cat, BL mod NQD Tear Into Jet boat, 55" Scarab, JET SWEEP R/C pool skimmer Rescue Boat.
    • MG1234
      • Jul 2015
      • 638
      Thanks ill get my kid to show me how to use the search feature ,
      • dasboata
        • Dec 2010
        • 3972
        LOL,,, when your ready I can prepare one for you !!
