Hey guys and gals - I found this 57mm prop I had laying around and I want to throw it on my Proboat impulse - what KV rated motor would be best to achieve 60-ish mph speeds at 6s without burning anything up - I have a 180A esc so I'm good there
57mm Prop Application
Tags: None
57mm prop is waaaaaaay to big for that hull. Even if you had a motor that could handle a prop that large, it's just stupidly oversized for the hull itself.
And.... There are no girls here.
Sent from my iPhone using TapatalkThere's a hole at the center of earth where the rest of the world sinks but i stand still...
Yeah that's what I was thinking - any ideas on what to use it for?Originally posted by Luck as a Constant View Post57mm prop is waaaaaaay to big for that hull. Even if you had a motor that could handle a prop that large, it's just stupidly oversized for the hull itself.
43" and up HullsNEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:
