Let's see your prop boxes
    I started off having my prop box as a multi compartment container. Then I came across a prop box you can buy. It looked cool but it didn't have near the room I needed and I also need room for tools and some spare parts, screws, rudders etc., so I came up with this..... this works out well in a pinch to grab and go to the lake. Let's see what you guys have come up with. I'm sure there's some neat stuff you've done. Here's mine. It's missing a few props.
  • Turbo Dan-O
    • Feb 2011
    • 292
    ^^^Very nice!!! I need to get something going like that. Too much time in these props for them to get banged up!
    Pursuit: T-180, TP 4060/1620kv. Genesis: T-180, GoolRC 2000kv. UL-1: Bone stock. MHZ Tsunami: Full tilt SAW project!
      • 7651
      HEY!!! I see a pair of counter rotating in there Travis. You holding out?
      BTW I'll get pics of mine up tonight.
        I was actually thinking about selling those big three blades. Well three of them anyway. I think they are52mm and way too big for anything I have anyway. So if you know anyone needing a set of big three blades let me know.
          Thanks! It was really easy to make, just a little time consuming. Worth it tho. It's a piece of birch wood to fit the bottom of the box, 8-32 screws and some sticky back foam on the divider. It's like drawer liner foam. Then the divider is epoxied in place. I'm using wing nuts for now but I just ordered (50) brass thumb nuts which will make it much easier to unscrew.
          • jj2003
            HIGH VOLTAGE ADDICT!
            • May 2011
            • 1501
            If you know anyone needing a set of big three blades let me know.
            I might know someone! Whats the shaft diameter and pitch? How much?
            "If guns cause crime, all of mine are defective"
            45"Speedfreek
            , Fightercat #068 ​, MyYoutube Vids
              • 9438
              Can't get you a pic right now but, I use clear storage boxes with individual compartments. I drill a hole in the center of every compartment and use a 8-32 bolt and nut then the prop, then fuel tubing on top to keep them from rattling much at all. The tubing makes it quicker to access a prop and the reduce some noise.
              • RaceMechaniX
                • 2825
                One layer for 1/4" and the lower for 3/16". The plates are 1/4" acrylic with numbers etched to cross reference with a table. I use a Hobbico twin stick radio box for the case.
                Tyler Garrard
                NAMBA 639/IMPBA 20525
                T-Hydro @ 142.94mph former WR
                  Tyler, I like that setup! Pretty impressive Colllection you have there too! Thanks for sharing
                    Not a bad idea but wouldn't that kind of limit you at a smaller amount of props? I guess you could stack two props in the same compartment though.
