Just put my blackjack29 leopard engine need help with prop size
  • Alexito Da Barber
    • Mar 2015
    • 1
    I just got my blackjack 29 inch I put a leopard 4074 2000kv 4 pole with a seeking 180 amp electric speed controller running 6s which prop would be recommended for best speed with This build which mm etc
  • Alexbarber
    • Mar 2015
    • 15
    Does anyone have a answer to this question I have the same prob
    • Make-a-Wake
      FE Rules!
      • 6057
      Don't know why you want to run 6s with a 2000kv motor but I'm thinking an x440/x442
        I agree! here is what I typed two days ago but didn't post because I thought I was being too long winded:
        Is this a new boat? why don't you run the stock set up till you are more familiar with the boat?
        Not saying that it can't be done, but to start on 6s with 2000kv, you should expect to start with a prop on the small side like a 440, certainly no bigger than 42mm, IMO.
        I have never run anything from 2000kv on with 6s, 5s was the most I did. I like to have a margin of comfort for myself. You are asking quite a bit from your components. People who know how to tune their boats do it, but whether it is a success or failure has so much to do with tuning and having a wide disposition of props at hand and knowing how to adjust the strut.
        • Alexbarber
          • Mar 2015
          • 15
          Just so I can know why wouldn't u run a 6s on a 2000kv motor ? After which kv till which kv motor u recommend a 6s I've had tv boats before but always left it stock it gained a few mph after I did the swap and adjusted the strut
          • Luck as a Constant
            Make Total Destroy
            • Mar 2014
            • 1952
            What's going on here
            Alexito da barber
            And
            Alexbarber
              Make Total Destroy
              • Mar 2014
              • 1952
              You can. Just a bit high on the rpm for sport running. Gonna have short run times but very fast.
              For 6s 1400-1600 is good
                Alexito da barber
                And
                Alexbarber
                Same guy, I think there was no response and he changed his user name..
                Sent from my D6708 using Tapatalk
                • Alexbarber
                  • Mar 2015
                  • 15
                  Same guy I accidently forgot my other email pw so I just made a account with my regular email
                    Wecome!
                    • Alexbarber
                      • Mar 2015
                      • 15
                      Thanks bud any one know the shaft size of the black jack 39 how do I search for a x440 x442 online which will fit my boat I dont wanna order one then it doesn't fit on the shaft, thanks again
                        3/16, you need to get balanced/sharpened props, not the raw ones. I cant see on my phone if they are instock or not.
                        Dasboata (Chris Hoffman) isba great guy to ask for props service. You can PM him as well.
                        • Alexbarber
                          • Mar 2015
                          • 15
                          Where can I just for inventory websites or eBay
                          • Alexbarber
                            • Mar 2015
                            • 15
                            ?? What u thibk
                            • Mr_3_0_5
                              • Jan 2015
                              • 32
                              This is very similar to the v3 set up I run m642
