Prop installation question
  • djviko44
    • Nov 2014
    • 26
    I know this question is not supposed to be for this thread but... now that i already have an UL-1, what other boat would you guys recommend me buy? I personally like the Pro Boat Impulse 31 or the Miss Geico 29.
    I like a lot the looks of the Miss Geico (I have already a MG 17 which i bought for "my gf" (as pickup boat) but i think i need another boat in order to race and have fun with someone else...) what would you guys say? Thanks!
    • PowerDemon
      • 351
      I had a Traxxas Spartan and loved it. It goes a bit faster than your UL-1 and it turns very well too. It is also an excellent boat if the water is too rough for your hydro. Hope this helps!
      37" Fightercat Shocker powered by Neu 1530 on 10S
      • Brewbud
        • Aug 2014
        • 117
        Have you had the flex shaft out yet? Make sure to grease up that shaft well before you run it too.
        Knowledge is knowing a tomato is a fruit. Wisdom is knowing not to use it in a fruit salad.
        PB BlackJack 29 / AQ Motley Crew / Tenshock Mini ECO / Phil Thomas Stealth
        • djviko44
          • Nov 2014
          • 26
          Thanx Brewbud, yes i took it out and greased it with marine grease
          Yesterday I went out to the pond but was unable to get my UL-1 running... It kept on diving on front (my prop isnt balanced and i haven't sharpened it either) i guess this has a lot to do with it...
          When i had the plastic stock prop i was able to run it fine...
          I have no clue on how to setup my prop... Do you guys think this is the reason why i wasnt able to run my ul-1 yesterday?
          Thx!
          • SirBudman32
            • Aug 2011
            • 609
            Yes, That prop need to be SHARP for it to work.
            Modified Jae21, Stock Jae21, Cheetah, Ul-1, Shock Wave 26 V2 (Rescue Boat).
            • djviko44
              • Nov 2014
              • 26
              Ok, thanks a lot! I'll try to find some videos on how to do it or take it to the store for them to balance it for me...
              • capnswanny
                • Feb 2012
                • 817
                After you get your prop cleaned up, the UL1 (most hydros actually) require a good amount of punch on the throttle to get out of the hole and up on plane. In other words, you can't take off slowly, they are nose heavy and like to submarine if you ease into the throttle.
                Have fun my friend!
                This is NOT a toy?!?
                • capnswanny
                  • Feb 2012
                  • 817
                  And for your viewing pleasure, here's a UL1 giving a couple FE30 hydros a run for their money...very motivational!
                  http://forums.offshoreelectrics.com/...ted-Sport-Hydr
                  I never knew a UL1 could be so competitive!!
                  • djviko44
                    • Nov 2014
                    • 26
                    haha Thanks a lot capnswanny, i'll try to sharpen my prop with some youtube help the thing is i also need to buy a balancer (i dont have one so i can't figure out if my prop's balanced or not)
                    anyways thank you all for all this help... best regards
                    viko.
                    • djviko44
                      • Nov 2014
                      • 26
                      Hello guys! I'm back with a quick question...
                      I don't know what's the best way to setup with my new L40x57/3 GrimRacer prop... but i've seen some videos and it seems that they all have the strut a little bit lower... could you guys tell me your opinion on as how further down shoult i leave mine? here's a picture of how it looks right now... (oh and by the way, my prop's already sharpened but i have to balance it still so im not over yet)
                      Thanks a lot! (can't wait to get my UL-1 running!!
                      • djviko44
                        • Nov 2014
                        • 26
                        Hello guys, i wanted to share another experience with you...
                        today i had a little time and made it to the pond... the thing is i saw a difference in my boat... it didn't nose-dive as a submarine as last week... but... it seems as if it didnt had too much power from the motor...
                        i don't know if i already damaged my motor by any means or could this be a problem still of my prop?
                        here are some pictures of how my prop looks...
                        Also wanted to ask you guys, the prop's bushing tends to go out of the strut... is that ok? or do i have to get it inside the strut and do something about it?
                        is the collet on the correct spot?
                        THANKS A LOT GUYS!
                          • 5660
                          I seriously don't think it is sharp enough, These props have to be really sharpened as SirBudman had pointed out. Your pictures show them to be perhaps sharp by your concept near the edge but they should also be thinned somewhat, I am no prop man but I bought Finished Props and the chord of the blades are properly thinned as well. I use Grim Racer 40x52/3 prop: http://www.offshoreelectrics.com/pro...dh-SB-aqub9720 it is very sharp, you can cut your fingers if you aren't careful. But this prop works really well with my UL-1.
                          Have fun my friend!
                          That is the trick, give the throttle a blip and when the tips of the sponsons are pointing up, pull full throttle and the boat will get on plane.
                          Your collet looks to be in the right spot. The bushing is called a "floating bushing" and if it drifts out , then it is working properly. It will be "stopped'' by the drive dog in any event.
                          Here is a video of my run: http://www.youtube.com/watch?v=Ub1CBE4cFkc#t=20
                          • SirBudman32
                            • Aug 2011
                            • 609
                            Yes bushing n collet are fine. Your prop is no where near sharp! Needs to be like a razor blade sharp.
                            • djviko44
                              • Nov 2014
                              • 26
                              Wow thanks a lot guys!
                              I'll do it right away... (To be honest, i was afraid i'd sharpened it way too far so i tried to do a safe sharpening...)
                              Ill do it and test it again...
                              I'll leave it ninja sharp!! Haha
                              Cheers and thanks again
                              • djviko44
                                • Nov 2014
                                • 26
                                Hello guys, me again!
                                I tried sharpening my prop way more... i got some results but... im having problems getting my UL-1 on plane... as you can see, on the first video im posing right here, my boat is going top speed (but its really slow) once it hits its own waves, it starts to plane and it flies beautifully...
                                what should i do in order to get it on plane right away? (do you think it still needs more sharpening?)
                                on the 2nd video it takes a whole lot of time to get on plane but then i tried to turn and i crashed it...
                                fun anyways... any input will be appreciated!
                                viko.
                                2nd try:
                                Thanks guys!!
                                oh and btw, the 3rd try suddenly my UL-1 didn't move (thought i'd break my prop) but found out after getting it back it happened because the collet got unscrewed... should the collet be really tight? do you think my prop needs to be sharper so the collet doesnt need so much effort to move?
