Should I upgrade to a bigger prop?
  • Turbinen
    • Jun 2014
    • 12
    Hi!
    My current setup is:
    • TFL Apparition
    • Leopard 3674, 1400kv
    • Fliermodel 200 Amps ESC
    • 6S
    • Octura X442 prop
    The boat runs very smooth and I'm very happy with my gear. However, I think there is room for improvement! After running at full speed for 5 minutes, the motor, ESC and batteries are just lukewarm. So I think my prop is to small, and that a higher pitch will give more top speed. (also, the acceleration is quite poor with the X442)
    Should I upgrade to a bigger prop, any suggestions?
    T
  • revoltrunner
    • May 2014
    • 646
    I went from a x442 to a x642 on my revolt
    1800kv on 4s and was quite happy with the improvement.
    • PowerDemon
      • 351
      Originally posted by Turbinen View Post
      Hi!
      • TFL Apparition
      • 6S
      • Octura X442 prop
      T
      With a 1400kv motor on 6S I would suggest an x445 or a m645.
      37" Fightercat Shocker powered by Neu 1530 on 10S
      • electric
        • 1744
        Agree, the easy way to progress is x440,x442,m445,m447. Each prop is just a bit more.
        • PowerDemon
          • 351
          Also the most expensive way as well...
          • Turbinen
            • Jun 2014
            • 12
            Thanks for all the advices.
            Since I don't like (or have the time) to prep a new propeller I'm gonna go for a CNC-milled 45 mm propeller with 2,52" inch pitch. I let you know how it goes.
            • olwarbirds
              Magic Smoke Wizard
              • Oct 2012
              • 1136
              cnc props dont seem to hold up to use running 6S, just a headsup...of course we are running alot higher kv motors....DJ
              • larryrose11
                • Jun 2010
                • 763
                Kenetic has CNC milled props.
                The M series is faster in general than the x series.
                they have a M642, and a M744
                • dasboata
                  • Dec 2010
                  • 3152
                  I have M 445 $ X445 M645 in stock I can Mod one up for you drop me a PM or e mail,, aluminium is not the right material for hi RPM props !thanks chris
                  • Turbinen
                    • Jun 2014
                    • 12
                    Update:
                    It took a while but this Saturday I finally tested the new prop: top speed increased 9 knots. Batts, motor and ESC are hotter than before but still acceptable.
                    I'm a happy camper
                    Thanks for all the feedback.
