Remember now I'm running a experimental junk setup ! lol
Need prop expert advice !
--Albert Einstein
FWIW I'm trying to see how the pitch alone improves the speed as Fluid mentioned I need more of it. I don't want my boat to have excess torque effect or thrust with larger props because I want this boat to be very smooth at high speed . The T29 isn't a high speed boat by design so keeping it calm and predictable at full throttle is my goal."Any intelligent fool can make things bigger and more complex... It takes a touch of genius - and a lot of courage to move in the opposite direction."
--Albert Einstein
In the video it sounded like not enough prop was in the waterOriginally posted by rearwheelin View PostFWIW I'm trying to see how the pitch alone improves the speed as Fluid mentioned I need more of it. I don't want my boat to have excess torque effect or thrust with larger props because I want this boat to be very smooth at high speed . The T29 isn't a high speed boat by design so keeping it calm and predictable at full throttle is my goal.32" carbon rivercat single 4s 102mph, 27” mini Rivercat 92mph, kbb34 91mph, jessej micro cat(too fast) was
Exactly ! With the same prop with more of it in the water I should have been in the 50'sOriginally posted by kfxguy View PostIn the video it sounded like not enough prop was in the water"Any intelligent fool can make things bigger and more complex... It takes a touch of genius - and a lot of courage to move in the opposite direction."
--Albert Einstein
Yea, it sounded like it was free-rearwheelin! :) I think a 442 or 642 will suit you better. I have a 642 I could send you to try.Originally posted by rearwheelin View PostExactly ! With the same prop with more of it in the water I should have been in the 50's32" carbon rivercat single 4s 102mph, 27” mini Rivercat 92mph, kbb34 91mph, jessej micro cat(too fast) was
Ok but if I like it you better plan on selling it lolOriginally posted by kfxguy View PostYea, it sounded like it was free-rearwheelin! :) I think a 442 or 642 will suit you better. I have a 642 I could send you to try."Any intelligent fool can make things bigger and more complex... It takes a touch of genius - and a lot of courage to move in the opposite direction."
--Albert Einstein
That's ok , I understand we all can get excited , I'm guilty of it too ! Maybe we can erase some of our posts hear and clean this one up including the quoted ones so those go away too. I understand each prop to do is alone of work and focus and no two are exactly alike . I would hate to see these remarks floating around forever. I respect both of your skills very much and Fluids . I can take a punch a little better these daysOriginally posted by dasboata View PostSorry to dirty up your post !
--Albert Einstein
I like really sharp props like the one I ran in the vid but I also bent on of the blade tips tightening the bullet nut with my hand ( wearing leather gloves) it bent in a way that it actually added pitch so I bent the other two the same. After my run they were straightened out again ! I suppose it was sharpened too much in the wrong area , it's a loaner prop
--Albert Einstein
I make mine sharp like you see in the pic above but I don't thin them too much where they will bend. I did buy one from a "professional" and the first pass I made it bend the blades back. $60 down the drain. Lol. I have a few other props you might be interested in trying. Pm me this evening g and I'll look through my box. I know I have a 40mm stainless one that did 53mph on my small cat.Originally posted by rearwheelin View PostI like really sharp props like the one I ran in the vid but I also bent on of the blade tips tightening the bullet nut with my hand ( wearing leather gloves) it bent in a way that it actually added pitch so I bent the other two the same. After my run they were straightened out again ! I suppose it was sharpened too much in the wrong area , it's a loaner prop
I took care of that, JHF,, You sound old and wise like me, I pretty much a big Ba-ll Buster LOLOriginally posted by rearwheelin View PostThat's ok , I understand we all can get excited , I'm guilty of it too ! Maybe we can erase some of our posts hear and clean this one up including the quoted ones so those go away too. I understand each prop to do is alone of work and focus and no two are exactly alike . I would hate to see these remarks floating around forever. I respect both of your skills very much and Fluids . I can take a punch a little better these days
