Hi guys, need some advice on prop choice.
I have just finished my first boat build. It's a 51" Mountain Hobbies Viper Mono. Motor is a TP Power 5650 850kv running 12s. Esc is a Hobbyking 180a HV, good to 14s.
I have props from x457 up to x470 and have tried them all. The boat so far has reached 56 mph per my gps.
My question is about prop size and motor / esc heat. If I run one of the bigger diameter props, x465, x467, x470 she does 56 mph at about 5/8 throttle, but comes back with everything pretty warm / hot. I'm not experienced enough yet to try and push the throttle any further.
If I run the x457, she still does 56mph, but I'm able to run full throttle, and she comes back just warm. Sorry I don't have any numbers to give you. I have a Eagletree logger coming from OSE, the one I ordered 7 weeks ago from Hobbyking never arrived, not unusual for them, another Paypal dispute, could write a book about how incompetent they are. Ok, back on topic.
I'm not sure if the heat build up with the bigger props is because their just too much for this boat, or because I'm only able to run the system at 1/2 to 5/8 throttle? I'd like to push the bigger props, as she feels like she has a lot more speed in her, but 56mph is pretty intimidating with a 24lb, 51" boat, and I don't know what she will do. I don't know if going past 5/8 throttle will give me more speed, or just fry everything inside.
It's my understanding that the motor and esc run best at their rated outputs. So, I'll assume that I need to prop the boat in a way that allows me to use full throttle all the time, while keeping the heat under control. Like I said, I get the same speed with a x457, as I do with a x470, but the x457 is full throttle, the x470 is 1/2-5/8 throttle.
Sorry if it should be simple, just not sure what to do. Prop to allow me to use full throttle, or get the confidence to push the bigger props. If I push the bigger props am I just going to smoke everything, or will the system be "cooler" if I run the big props at full throttle instead of half, and I'll gain the extra speed.
I hope you understand, and can share some of your experience and knowledge. Should add, my goal when I built this was to reach 60 mph, so I'm close.
Glen
Glen
