Turn a X642 into a M642
  • Luck as a Constant
    Make Total Destroy
    • Mar 2014
    • 1952
    so i lost a prop the other day. pretty bummed, so i ordered another.
    figure ill go thru what i do. first my tools and the respirator. a good one.IMG_5463.jpgIMG_5460.jpg
    Then mark where i want to remove material on the tongue, and leading edge
    Next to an m445 its looking decent so far. not sure whether to round the tips or not....
    tomorrow ill get to thinning blades and some other stuff. stay tuned
    Make Total Destroy
    • Mar 2014
    • 1952
      To make it like a m series, you need to de-tounge it. In other words cut back the rounded part closer to the center.
        Make Total Destroy
        • Mar 2014
        • 1952
        UHm..... I removed the tongue and some of the leading edge.
          Make Total Destroy
          • Mar 2014
          • 1952
          I fixed my post. I realized my terminology was off. My bad.
            I'm always a little timid at how much I remove because I keep forgetting if i mess it up, it's only a $13 prop hahaha!
              It is about the cheapest thing in this hobby to mess with, You can do a few in the AM and play with em' in the PM. Loads of fun
                Make Total Destroy
                • Mar 2014
                • 1952
                hehe yup. it only sucks when you do one up nice and lose it.
                  Just lost my way cool 447,best I have done. Hope I can redo it.
                    Make Total Destroy
                    • Mar 2014
                    • 1952
                    it really fellates cattle when it happens doesn't it?
                    any thoughts about my prop? should i round the tips ya think?
                    • 785boats
                      Wet Track Racing
                      • 3423
                      No.
                      I would back cut it about 3/32" at the hub from zero at the tips.
                        Make Total Destroy
                        • Mar 2014
                        • 1952
                        No.
                        i usually square off the trailing edge and leave it straight. thats the edge you're speaking of yes?
                          Make Total Destroy
                          • Mar 2014
                          • 1952
                          So with a rough half round file I went at the convex side of the blade thinning it out over the entire blade.
                          Then on to a finer file to smooth out .
                          Finally, for now I square off the trailing edge.
                          Now onto the balancer. Not bad for wingin it
                            Make Total Destroy
                            • Mar 2014
                            • 1952
                            So now it's going to get 400 on both sides, then 600 then 800 only on the convex side. Then back to the balancer.
                              Make Total Destroy
                              • Mar 2014
                              • 1952
                              So I ended up going with 320 on both sides the 600-800-1200 on the convex side. Then I use a fine file and file into the edge I want sharp. I back onto balancer, and back and forth till it's balanced and razor sharp. hard to tell from the pics but it's ridiculous sharp.
                              Then to keep this one, unlike the first one I'll use a good nut and locktite
