Just ordered a mean machine need prop help please.
  • Luck as a Constant
    Make Total Destroy
    • Mar 2014
    • 1952
    What?
    Guys, I posted a link to a sharpened balanced m445.
    I dunno what I missed in posts 8,10 and 11.....
    Someone clue me in
    • Gusmoyer11
      • Apr 2014
      • 171
      Originally posted by Gusmoyer11 View Post
      Lol, you missed #8, and #10
      Sorry I didn't see post 12. Thanks for the link, and no I haven't ever worked an rc prop so I'm sure there's a learning curve. Is there anyone here that does prop work?
      • gsbuickman
        • Jul 2011
        • 1292
        QUOTE=Gusmoyer11;563608]Oh ok, I didn't realize counter clockwise in rc land was standard. I'm a mechanic for the USCG and clockwise is standard in the marine world. Thanks for clearing that up.[/QUOTE]
        Technically you can have the prop spinning either direction. all you have to do to change the motor direction is swap 2 of the motor leads around and run the appropriate prop.
        • Alexgar
          • Aug 2009
          • 3522
          You will also need a flex for opposite turning or the flex will unravel
          • Gusmoyer11
            • Apr 2014
            • 171
            I'm going to be running the normal single set up on this thing. No need to replace brand new parts that are already paid for.
              Make Total Destroy
              • Mar 2014
              • 1952
              Gus, just stick with the prop in the link I sent you.
              It's what you need.
              • Gusmoyer11
                • Apr 2014
                • 171
                Well it seams I'm going to order the m445 to start, also looking at the y535 found it in another fe fourm as a good starting point. I'll also be testing a 26 bling rocket with a 1600 kv out runner.
                  • 5660
                  Originally posted by Luck as a Constant View Post
                  What did I miss?
                  Not a thing IMO, however, Gus said he is a mechanic for the USGC, therefore post #13 infers that Gus should have all the tools and perhaps knows how to b/s/p/ a prop...
                  This one is a bit tricky, I need help myself.
                  M445 is a great prop, start with this one as suggested...
                  • Gusmoyer11
                    • Apr 2014
                    • 171
                    I'm not sure the tools for a 28-36 inch diameter propeller are the same as a 44 mm diameter propeller. As stated before I'm still new the the fe boat hobby. The first one will be ready to use, I will be ordering the balancer and some small files along with some raw castings.
                      • 7651
                      There are all kinds of links to read before prop work begins. Really all the sites for the 1:1 like Mercruiser's "how to" still apply to the small guys.
                      • de-pro
                        • Aug 2011
                        • 180
                        Nice boat and nice build. I built similar hull except running on 6s with a leopard 4082 1600kv and an Octura M545 prop. Lots of power and things stay reasonably cool
