Prop recommendation for a 30" tunnel....
  • Rinochasr
    • Nov 2013
    • 22
    Hey, I'm looking for a prop for a 30" tunnel hull. It's running a leopard 4082 1600 on an o.s. Leg on 6s. My goal is approx 60mph, any suggestions would be great, thanks.
    If they fit under the cavitation plate try a Prather P-230 or Octura x648.
    • Rinochasr
      • Nov 2013
      • 22
      Ok thanks, if they don't fit, would you ever consider running without the cav plate?
      • HTVboats
        • 936
        Not sure what tunnel you have but a 4082 might be a little more power than you need. It will work but you'll be upside down more than you want. As for props I run an m445 or m545 on our Q tunnels with a 1600 1521 Castle. These are 32-36 inch hull that run in the 55-65mph range. A smaller hull may only be faster to the scene of the crash.
        Mic
        Mic Halbrehder
        IMPBA 8656
        NAMBA 1414
        • Rinochasr
          • Nov 2013
          • 22
          That may very well be the case. The hull is about ten years old or so. I used to run a graupner brushed outboard on 20 cells Nimh and it did about 40, so I'm hoping I don't ruin the boat with this motor.
          Btw- it's made by a company called maus motorsports, has anyone ever heard of it?? I've never seen another and am curious if the company still exists.
