Stock rio ep prop.
  • Megabiker98
    • Jan 2013
    • 253
    Stock rio ep prop.
    What size prop is the STOCK plastic prop on the rio, what would be a good running metal prop, it's for my brother just so he doesn't have to worry about breaking them if he accidentally hits the beach. I don't need faster bigger props or any of that just a metal one that's almost the same dimensions as the stock ones!
    Stock prop is 42mm x 1.4 pitch.
    I like the x440/3 prop,
    It helps stop the torque roll and give more top end speed to.
    Also it will run a little cooler with that prop,
    I have one that is modded to brushlees now,
    What volts is he running in it ?
    • Megabiker98
      • Jan 2013
      • 253
      Wow, that sucker is $50! He is bone stock and running 7.4v 3000 mah nimh dynamite batteries!
      Also, that prop has a 3-16 haft diameter stock flex is 1/8th? Is there and adapter or something that would be used to make it work?
        Hi,
        Shop around in the swap shop for better deals on props and stuff.
        Also a cnc prop may be a good choice for his boat to.
