Pitch vs prop size
  • Mulisha
    • Apr 2013
    • 241
    Pitch vs prop size
    Hi I'm looking for some info on prop sizes and the pitch. I understand about torque roll with large props and the amp associated with different sized props. But would like to know about going up in pitch or in size and the effect positive and negative.
    Example 43x1.4 or 42x1.6 the later has more total pitch but the first has a larger diameter prop and how will they effect the boat. Mainly looking at cat and a tunnel hull so I know both will run better on certain props.
  • Jason4636
    • 712
    Subscribed
    • NativePaul
      Greased Weasel
      • 2770
      The 42x1.6 will give more speed and more prop walk, the 43x1.4 will give more acceleration and more torque roll.
      • Mulisha
        • Apr 2013
        • 241
        So with a twin cat counter rotating I should feel that as bad as V or tunnel hulls
        • NativePaul
          Greased Weasel
          • 2770
          What? I fail to comprehend any meaning form what you just said.
          Torque roll isn't such a problem for a decent oval cat or a tunnel as it can be for a mono due to the inherent lateral stability of the twin hulls.
          Prop walk can be an even bigger problem for a cat than a mono as all the aero lift from the tunnel means there is less hull in the water to counteract it, a higher deadrise angle wheter on a mono or a cat will reduce the effect of prop walk, as will lowering the prop.
          • Mulisha
            • Apr 2013
            • 241
            Sorry I meant shouldn't see those effects. Won't the props counter rotating cancel the prop walk and torque roll?
            • ReddyWatts
              • 1756
              PROP Pitch/inches
              X437/3-- 2.072
              X438---- 2.100
              X440---- 2.198
              X440/3-- 2.198
              Y536---- 2.200
              Y537/3-- 2.279
              X442---- 2.310
              X637---- 2.368
              X445---- 2.478
              X640---- 2.512
              X447---- 2.590
              X447/3-- 2.590
              X642---- 2.640
              M545---- 2.655
              X448---- 2.660
              X450---- 2.758
              X450/3-- 2.758
              X645---- 2.832
              Y547---- 2.849
              X548---- 2.850
              X452---- 2.870
              X452/3-- 2.870
              X646---- 2.896
              X646/3-- 2.896
              X455---- 3.038
              X455/3-- 3.038
              X648---- 3.040
              X457---- 3.136
              X457/3-- 3.136
              M650---- 3.190
              X460---- 3.304
              Y557---- 3.449
              X560---- 3.540
              X427---- 1.498 0.125
              X430---- 1.652
              X431---- 1.708
              X432---- 1.764
              Y531---- 1.877
              X435---- 1.932
              X632---- 2.016
              Y534---- 2.059
              Y535---- 2.125
              ReddyWatts fleet photo
              • Mulisha
                • Apr 2013
                • 241
                I'm more interested in the effects of small prop high pitch against big prop small pitch, and how they affect the boat
                • electric
                  • 1973
                  From what I know it seems you can get a bit more speed with a higher pitched prop (abc 1.6) pitch than a simliar prop octura 1.4 pitch with a larger diameter for the same amount of amps. This is because to get the same total pitch with the "x" octura you need more diameter than you do on the ABC. There is also the issue of which prop is more "efficient". I am discovering that over 60mph you are really looking for higher pitch (cupping the prop, bigger pitch) because the diameter becomes to large and that causes some amp draw issues as well as other handling issues.
                  Most of the "custom" prop makers seem to be cutting down the diameter of the x props and pitching them up. Same effect as I just described above. There is a a whole "lot" of knowledge about props out there, but this is my simple observation.
                  Then there are one thousand other issues to balance. Prop lift, thrust cone, 2 blade vs 3 blade, cupping, polished or not, cutting down the leading edge.....it just goes on and on.
                  By the way 2 blade is generally better, x props should have the leading edge cut down like an "M" prop does.... there are always exceptions to the rule though...
                  • h2o 1
                    • Sep 2011
                    • 854
                    http://forums.offshoreelectrics.com/...hp?albumid=991
                    Click and read. Theres alot of great info on props in Sweetaccords album. I look at this weekly!lol,Mark
                    • Mulisha
                      • Apr 2013
                      • 241
                      thanks heaps h2o 1 that link was great so much info on there still looking through all of it
                      • BHChieftain
                        Fast Electric Addict
                        • 2051
                        Sometimes a lower pitch prop can actually yield more speed-- sometimes the higher pitch prop does not let the motor reach full RPMs. I had a 6 series prop on my 29" mono with a 2200kv neu motor and it was running a bit too warm, I dropped down to a 4 series prop with less total pitch, and the boat ran cooler AND faster... what a surprise!
                        Chief
                        • martin
                          • 2881
                          Quite often going down in pitch but up in diam (overall pitch will be lower even though diam is larger)will yeild higher speeds, larger diam is sometimes more efficiant.
