Supervee 27 prop
  • bryantkalagian
    • May 2013
    • 4
    Supervee 27 prop
    Hey everyone, I searched around and didn't really find a solid answer. I have a supervee27 with a 2550kv motor and and running two 7.2v 5000mah batteries. If you could point me in the right direction to start, that'd be awesome. Thanks
  • jetskier
    • Jan 2013
    • 230
    I have a stock SV27 running on single 4S and I'm very happy with Grimracer 2 blade 42X55
    • Heaving Earth
      • 1877
      How about an x438
      • TheShaughnessy
        • 1419
        Try a x437/3. Watch temps
        • IRON-PAWW
          • Oct 2011
          • 314
          I have an sv27 running a 2200kv leopard on an M445. Temps are good, but the hull has difficulty handling the speed. I think the suggestions above are on the money considering your 2550kv motor. Will go like the clappers.....
          PERTH AUSTRALIA
          || 2 x SV 27R || Impulse 31 - ver1 || Traxxas Spartan || Kintec Pursuit || Zonda Cat 41" || Insane FE30 || OuterLimits 870mm || TFL Ariane 36" || ProBoat Zelos 48 ||
          • bryantkalagian
            • May 2013
            • 4
            Alright thanks guys!
            Also what would be the advantages of the three blade?
            • TheShaughnessy
              • 1419
              Less torque roll and a lil smoother through the corners, more low end bite. It's a good SV prop. You are gonna be spinning it pretty fast though so it may be a little much that's why I say watch temps. Batteries are gonna be the weak link though, it should be ok just keep a close eye on temps the first couple runs
              Also where at in CA?
              • bryantkalagian
                • May 2013
                • 4
                Ok good info. What would be an acceptable temp for all the components? I have an IR temp gun. Also I know what you mean about the batteries, eventually lipo's are in the future haha. And I'm in San Clemente, but I mostly use my boats out in Havasu.
                • TheShaughnessy
                  • 1419
                  Max temps I would say are ok are 150 ish on the motor 130-140 on the esc board and like 160 on the capacitors. That's max temps after a full run. For longevity temps around the 110 range would be better on all components. What kind of connectors are you using? They will likely be pretty warm after a run, anything over 160 I would consider a larger connector or an inspection of the solder joint.
                  Do you have any props now or are you going to be ordering some up?
                  • bryantkalagian
                    • May 2013
                    • 4
                    Alright sounds good. I'm using deans ends. And I have a Grim 40x55 I believe it is, but I'm planning on ordering others
