Warning: Trying to access array offset on null in phar://.../vb/vb.phar/bbcode/url.php on line 2 Prop polishing? - RcBoaters Forum
Prop polishing?
  • Megabiker98
    • Jan 2013
    • 253
    Prop polishing?
    I would like to polish a couple of props but have a couple questions, I know u r supposed to use 600 grit wet sandpaper but, is that all? U just wetland till its shiny? any issues I may need to take into account, things to be aware of??
  • hydro_pyro
    • Mar 2013
    • 104
    Stay off the trailing edge... Don't soften the sharp 90 degree edge.
    You can carefully finish with a high-speed buffing wheel on a Dremel with a suitable wax-brick buffing compound.
    '89 Hydrostream Vegas XT w/ Mercury 2.4 Bridgeport EFI - 240hp - 95mph
    ProBoat Blackjack 29 - 58mph, Traxxas Villain, Traxxas Slash 4x4, Align T-Rex 450pro, Blade mSR, Blade mCPx, Dynam Cessna 182, Blitzworks F/A-18, UM P-51, UM SU-26XP
    • Megabiker98
      • Jan 2013
      • 253
      I'm probably gonna start on my stock proboat one, then my octura x642 then my newest m445 if in capable, ill upload pics so u can point me in the right direction
      • detox
        • 2357
        I use these with my Dremel
        • hydro_pyro
          • Mar 2013
          • 104
          I used small sanding discs and soft abrasive wheels on my Dremel tool to do mine.
          • Megabiker98
            • Jan 2013
            • 253
            I'm not gonna use a Dremel, I'm using sandpaper, that works right? Do I NEED a mask when working with an octura prop, even though its gonna be submerged in water???
            • Rumdog
              • 6667
              No. There won't be any airborne dust while wet. Especially so when just polishing.
              • Megabiker98
                • Jan 2013
                • 253
                Ya I was pretty positive I wouldn't need it, but hey safety first so u might as well ask! Hahaha
                • Megabiker98
                  • Jan 2013
                  • 253
                  I can't seem to get my pics uploaded from my phone right now, website isn't cooperating. I did one blade on the stock and might need a little more wetsanding but, want to know ur guys opinion, ill try and get some pics if I can get around the problem
                  • Megabiker98
                    • Jan 2013
                    • 253
                    I got one, if u guys need more I can try again in a little while, seems like its because I was trying to upload 2 at a time
                    • egneg
                      • 4759
                      That is fine ... I usually stop at 400 grit.
                      IMPBA 20481S D-12
                      • JimClark
                        • 5913
                        Ok I just got to ask Is the reason you want to polish the prop that you think it will go faster?
                        Billy Graham
                        • Megabiker98
                          • Jan 2013
                          • 253
                          No, I just want one to have a couple shiny props. The stock proboat is gonna be the one I put on when it's on my desk
                          • T.C.
                            • Sep 2009
                            • 245
                            Question for people smarter than me..................
                            Most people scuff the bottom of the hull (make it a dull finish) so the water wont stick to it thus slowing the boat.
                            If water sticks to a shiny slick finish then why would you not want a polished prop ?
                            The prop is the wheel,gear,traction for the boat, so wouldn't you want a surface that grabbed the water ? (shiny)
                            T.C.
                            • Megabiker98
                              • Jan 2013
                              • 253
                              T.C.
                              I would have to say that a polished prop doesn't give u anything because its already spinning so fast that it doesn't make a difference whether its polished or not, anybody correct me if I'm wrong! That's just a guess from me
