As the title states I have a octura x645 with a setup of tacon 4074, seaking 120 amp I've heard of problems with bounce and some saying it has to do with the props. Is this at all true? Will the x645 produce that bounce? Should I upgrade to say and m445 or what would u recommend for this setup? I would like to stick with the 645 if at all possible but I am willing to spend the extra cash to get this setup correctly!
Mystic x645 any good?
Tags: None
Sometimes a 1.6 pitch prop creates too much lift & lifts the back of the hull off the water. COG & strut angle adjustment can dial it out. An m545 seems to work well on a lot of cats, but try the M445 first. But it all depends on what KV the motor is, & what voltage you are running. I'm assuming 4s with around 2000kv to 2200kv. But as sirislash suggested, a 180A ESC would be a wise upgrade. The 120A night struggle a bit.See the danger. THEN DO IT ANYWAY!!!
Using 2 2s lipos, 5,000 mah gens ace hard case batteries! A 2100 kv motor! And will an upgraded flex shaft be needed or not?? Is it critical to run an upgraded one or no??
When u say a .150 GLUED what do u mean by that??? Like u glued it over the stock flex shaft?? Or u glued it to the motor shaft???
I glue the cable to the shaft with Loctite 638 instead of the silver solder method. I have had waaayy less failures this way. Actually I have not had one of my glued cables fail.Originally posted by Megabiker98 View PostWhen u say a .150 GLUED what do u mean by that??? Like u glued it over the stock flex shaft?? Or u glued it to the motor shaft???
Ok if I get the seaking 180 amp will these clamps for the water outlets??
http://www.offshoreelectrics.com/pro...od=dh-GPMQ4172
Ok back to the whole prop thing then, which would be a better choice a m445 prop to replace my x645 or a ose flex shaft???
I was merely stating that the glued .150 shafts were plenty strong for our application.And thanks Martin for grabbing the ball that I dropped
Mega,all you have to do is raise the strut a little at a time to get rid of bounce usually. You are running the boat light so it may be different than mine.
