Smallest prop for 1/4" flex
  • Hp88
    • May 2012
    • 24
    Whats the smallest diameter prop you can get that fits 1/4" flex cable,
    For what use? Octura's smallest is the 2.4/3 at 61mm, but it is a high lift hydro prop. There are bunch of 67mm props, they are the next smallest on my chart. You'd probably be better off getting a stepped-down stub shaft if you need small props.
    • ManuelW
      • Oct 2010
      • 786
      When you order at PropShop UK you can ask for a 1/4" bore. The smallest I got so far was a 55mm hydro prop in stainless steel with 1/4" bore.
      regards,
      Manuel
      • egneg
        • 4759
        What size were you looking for? You could always cut it down if it's not to big of a difference.
        IMPBA 20481S D-12
        • T.S.Davis
          • 6266
          Or just get a stepped shaft that will take 3/16" props. So with that you could go down to an Y536. I run a stepped shaft for Q. Overkill but I got tired of fixing them.
          Noisy person
          • tornado2405
            • Feb 2011
            • 4
            Hi
            I have Octura X465/2 (64mm) whit 1/4'' bore.
            I can sell you.
            • dasboata
              • Dec 2010
              • 3972
              I have a bunch of 55MM Prop Shops with 1/4" shaft in stock e mail me if interested thanks chris
