Originally posted by marko500
View Post
what prop? PT hydro 1515 1Y
If my wife knew I had a grand in my 47 incher she would not be happyNEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:
well I just ran the boat with a m445 and it is hauling butt. the gps only read 28 but it is not getting good recep. inside the hull. I raised the strut from 7/8 to 3/4 and put a little angle to raise the bow. it was flying. i am going to try another run with the gps on the outside.
well I ran the boat with a x640 and my speed was down, no change in set up from m445. so for now I will stay with the m445 until I can find some one to run with that has some knowledge to tell me if I need to do some set up changes. my temps are about 110 after 5 min.
Give the ABC H-5 prop a try. It's 6mph faster than the M445 on my hydro (33" Whiplash) so it could be similar on your PT. That was with an 8XL 2075 kv motor. But I also run it on a TP Power 2200kv motor in it too. It has a bit more lift than the M445 so you might need to raise the strut a smidge.
http://www.offshoreelectrics.com/pro...p?prod=abc-H-5See the danger. THEN DO IT ANYWAY!!!
that prop has a bit more pitch than m445, what were your temps w/ the h-5Originally posted by 785boats View PostGive the ABC H-5 prop a try. It's 6mph faster than the M445 on my hydro (33" Whiplash) so it could be similar on your PT. That was with an 8XL 2075 kv motor. But I also run it on a TP Power 2200kv motor in it too. It has a bit more lift than the M445 so you might need to raise the strut a smidge.
I seldom check the temps after a race anymore except with my finger as the setup is so predictable with either motor.
I think the temp was around 50c on the 8Xl & 48c with the TP Power motor when I did do it some time ago.See the danger. THEN DO IT ANYWAY!!!
well i ran the boat at at club test and tune day a couple weeks ago. I had a x448 and boat ran great the guys at the pond were impressed for me being a first time boater. the gps said 52.2mph and was averaging over 220amps and temps were at 150* after 5 laps. someone helped me out and let me try a m445 back cut and and some other major cutting, 53.3 gps but flipped 210amps avg. but temps way down to 120*
