Need help reducing lift please
    • 6057
    I am running counter rotating x447's and want to reduce lift, do i simply detongue? Thanks!
  • dana
    • Mar 2010
    • 3660
    Detounge will help
      • 6057
      Thanks
      • oscarel
        • Dec 2009
        • 2373
        Rounding tips helps as well.
          • 6057
          It sounds simple but how is that done?
          • oscarel
            • Dec 2009
            • 2373
            I don't do them but when having them done requesting low lift will result in rounded tips.
            Star or pointed tips have higher lift.
            • oscarel
              • Dec 2009
              • 2373
              See if this helps
              Sent from my SAMSUNG-SGH-I997 using Tapatalk 2
              • twissted
                • 896
                If you cup the prop it push and get less lift.
                  • 6057
                  Thanks Gents!
                  • TheShaughnessy
                    • 1461
                    Detounge won't do much for lift. Backcutting is more for lift removal, cupping and rounding tips should help.
                    • dasboata
                      • Dec 2010
                      • 3972
                      This is correct !
                        • 6057
                        Sounds like we're on the right track here...............can I also detoungue some..........will that have any effect?
                        • RandyatBBY
                          • 3943
                          Detounging frees up the prop for RPM. Lift is caused by the tunnel or cone of the prop wash. narrow the tunnel or cone and the prop will have less lift. there is three ways to do this: (Or two cuts I like and one bending edges or cupping)
                          You can cut the 1/2 moon out using different sizes to control lift depending on how big. Some props do not have the strengths to be cut this way and will cause the blade to break a H-10 is one of them.
                          Randy
                          BBY Racing
                          • RandyatBBY
                            • 3943
                            I use a dremel for the cuts and have made a lot of pliers but these are my favorites
                            Randy
                            BBY Racing
                              • 6057
                              Thanks for chiming in here Randy, in post #13 is the prop in pic 1 and 2 the same one in progressive states of modding...........or two different cuts?
