UL-1 Prop
  • jfrancisco892
    • Feb 2012
    • 593
    UL-1 Prop
    I am currently running a 42x55 grimracer and am looking for more speed as there is more room for propping up due to low electronics temperatures. I have run a m445 which the boat does not seem to like, a 40x57 3 blade which works but is difficult to get on plane and has similar speed and handling characteristics of the 42x55. Anyone have any suggestions on what to try next? I am thinking of trying an abc h4, prather s220, or a grimracer 42x66. Let me know what you think.
  • jamie
    • May 2011
    • 206
    The H4 has fairly aggresive pitch watch your temps ... also why didnt the boat like the M445? where was your strut, angle, cog etc.
    • jfrancisco892
      • Feb 2012
      • 593
      Does anyone know the difference between an h4 and a grimracer 42x66.
      • longballlumber
        • 3417
        James,
        I am pretty sure they are the same prop... The Grim 45X68 is the same as the ABC H5
        Here is an ABC Prop Chart
        Later,
        Mike
        • jfrancisco892
          • Feb 2012
          • 593
          I have done a lot of changes since last running the m445, but it was very walky and had high temps. I may try it again sometimes but i feel i would have to run the strut very low with some negative angle. With smaller props it seems to be much more stable. Thats why i am looking for something in the 42mm range just to experiment with. My ul-1 is also highly modified so the strut position and angle is probably not comparable to other ul-1s.
          • RandomHero
            • 104
            go with the 45x68 i run it on mine but u need a better water pick up!
            • jfrancisco892
              • Feb 2012
              • 593
              I can imagine my motor exploding already. What water pickup?
              • detox
                • 2357
                The simple x442 is allways overlooked. I like them sharp and thin. Try adding a little more cup at tips for greater speeds
                Cup: I have my own very simple way of doing this. Others would probably laugh, but it works. No stupid special pliars, no ball anvil. All I use is a regular pair of pliars.
                • dana
                  • Mar 2010
                  • 3660
                  I never had any problem getting mine to plane on l40/57/3. Thing was a rocket too...
                  How are your prop sharpening skills anyways?
                  • detox
                    • 2357
                    That prop is very difficult and time consuming to sharpen, but it is a good prop. To sharpen I use a strong pair of Walmart #3 reading glasses and take my time. Small course and medium files then polish with dremel.
                    • detox
                      • 2357
                      Thanks to properchopper it goes something like this (cupping tips).
