Under propping?
  • dana
    • Mar 2010
    • 3660
    Under propping?
    Sorry if this has been discussed, but, can excessive heat be generated from under propping a motor? Thanks
    Yes, it is similar to running without a load. At full throttle what power is not being used to spin the too-small prop is converted into heat.
    • dana
      • Mar 2010
      • 3660
      Thanks jay -)
      • Serpents811
        • Oct 2011
        • 381
        You should try a grim 42/55 on your mm , is the same final pitch as m440 but 2mm larger in diameter
          Thanks for the post! didn't know that...
          • dana
            • Mar 2010
            • 3660
            Tommy, I've been thinking about a x642 with tongue removed
            • Serpents811
              • Oct 2011
              • 381
              M440 final pitch 2.198 grim 55mm = 2.16*!**
