Best prop...
  • Captain Tom
    • 25
    Will be racing at Brick Pond, in Elimra, NY...6 lap races. I will be running my UL-1 built by Darin Jordan. I have a Nemesis 9XL for the Titan now. Thanx for your info.
    • madmikepags
      • Aug 2012
      • 1371
      9XL in the titan 29 would use a 447-450
      We call ourselves the "Q"
      • Captain Tom
        • 25
        ...and what brand prop would that be? I haven't familiarized myself yet with all the prop numbers & letters. Thanx
        • Old Sloppy
          Harry from Atlanta
          • Jul 2007
          • 201
          Originally posted by Captain Tom View Post
          ...and what brand prop would that be? Thanx
          that would be "Octura" brand.
          Harry
          from Atlanta
          60" Expresscraft SuperCat
          (2) 2028 Castle motors 64.7 mph
          10s3p with x450/3 props
          15,000 mah 40c cells,
          • Captain Tom
            • 25
            Thanx...
            • Captain Tom
              • 25
              M or X...2 or 3 blade?
              • highflyerbill
                • Jul 2011
                • 206
                No m447 just X447 or X447/3 I think OSE has prop charts on there web site ,
                  [QUOTE]
                  The stock UL-1 60 amp ESC. 2 x 4000mAh 25c batts in series. Batts get warm...motor ok. Pics are available. The Titan was built for racing, bought from the former owner.
                  I do not think the ESC is progammable. Once the boat is up on plane it's fast and handles very well. Takes a few seconds for that though.
                  Try some 35 or 40C batts to bring the temps down on batts, maybe 4500's to 5800's also...
                  • Make-a-Wake
                    FE Rules!
                    • 6057
                    If anyone else has noticed, if you buy Zippy/Turnigy Lipos at Hobby King for Sport running, the 40c batts are often less than the 30-35c possibly due to folks not really looking at the 40c's thinking they are more $$. There are cases where the 40c's are literally cheaper than the 35c's.
                    • Old Sloppy
                      Harry from Atlanta
                      • Jul 2007
                      • 201
                      The "X" props have more low speed grip, for fast take off with slightly less top speed.
                      The "Y" props have 10% more pitch than "X" props, but are otherwise similar to "X" props.
                      The "M" props have less low speed grip, slower take off but more top speed.
                      The "V" props slip like crazy during take off, but yield maximum top speed. (most boaters stay away from this series)
                      The 2 blade props slip more on take off, then have higher top speeds. (in general)
                      The 3 blade props slip less on take off, then have slightly less top speeds. (in general)
                      I will mention certian setups will act differently.( so testing on your boat is required)
                      Harry
                      from Atlanta
                      • highflyerbill
                        • Jul 2011
                        • 206
                        Old sloppy I don't mean to step on you ,but how do you get 370HP with the battery packs available today . Or is it just 3.70HP.
                        • dana
                          • Mar 2010
                          • 3660
                          In my experience with my df26, the x440/3 has more top speed than the x440/2. ALOT of people on here say two blades are faster than 3 but I have always found the opposite. I suppose it depends on the boat tho....
                          • Make-a-Wake
                            FE Rules!
                            • 6057
                            A set of 5000mah 40c's would give you 200 constant amp output as opposed to the 100a constant you have now.
                            You may also consider detongueing an x442 to make an m442 out of it..............
                            • dana
                              • Mar 2010
                              • 3660
                              I wish octura made a wider range of props. For example, a x640/3
                              • RandyatBBY
                                • 3944
                                Make your own. I did it, I have a gig that I take two props, cut and silversolder to make a three blade out of. I did it with the OM21 back in the day when it was the big winner in N2.
                                Also a three blade prop on a Mono will always ride smoother.
                                Randy
                                BBY Racing
