What prop is compatable to the octura x442
  • itspfo
    • 32
    Octura x442 are all on back order. What other prop is the same or compatable with the octura x442
    I need a prop now do u no of another site that might have the octura x442 for sale
  • martin
    • 2881
    Try Kintec Racing.
    • backbayboy
      • Sep 2009
      • 82
      Steve has the 442 Balanced and sharpened in stock, right now, they dont stay in stock I'd jump on it. I've purchased one and it's great.
      http://www.offshoreelectrics.com/pro...rod=octsb-x642
      Traxxas Blast,Spartan,Villian. Aquacraft Revolt,SuperVee, UL-1, Wildcat, Gunslinger27,Atlantic Harbor Tug, Bristol Bay trawler.Cajun Cmd. ProBoat Widowmaker,BJ26/29,Fastech,Stiletto,Volere,Mystic,Impulse 31.Deltaforce 29" Mono. 37" Mystic FC , Atlantic Yacht
      • b20btec
        Senior
        • Aug 2011
        • 252
        funrcboats.com
        • 1945dave
          • Mar 2012
          • 295
          Consider any of the Octura 442 props. The original 1442, the X442, and the M442. Just because your dealer does not have one consider the others. The original had more blade area and the X series changed the tip shape and the M series just detongued the basic shape.
          Dave
          • siberianhusky
            • Dec 2009
            • 2206
            Pretty sure there isn't a Octura 1442 goes from 40 to 45mm, if there is it's a very different prop than an X or M series. More lift. More of a rigger/hydro prop.
            The Grimracer 42mm x 55 prop is close in speed but has some different characteristics. (read that it's an ABC prop, I personally don't know)
            The tfl props I believe are Chinese copies of Octura X props, the only 42mm I've seen lately though is a factory back cut prop. I have a couple different sizes, nice props.
            I think Kinetec has the x442 in stock, shows you can buy one at least. No indications of stock.
            • TheShaughnessy
              • 1461
              http://www.kintecracing.com/Octura_Props.html. about 60% down the page.
              • Make-a-Wake
                FE Rules!
                • 6057
                If your setup can handle just a bit "hotter" prop, the s215 would work well. 40.6mm dia and 1.5 pitch. Total pitch is 0.19" more
                http://www.offshoreelectrics.com/pro...i-prather-s215
                • highflyerbill
                  • Jul 2011
                  • 206
                  You can also try a x440/3 blade and get about the same results as a 442
                  • Heaving Earth
                    • 1929
                    42x55 is close
                    X442=42x58
