what prop to use
  • itspfo
    • 32
    what prop to use
    ive got a 32 in cat running a leopard 4074 with the t-180 esc need a prop
  • stadiumyamaha
    • 1371
    That's the kv of the motor and what's your cell count?
    • stadiumyamaha
      • 1371
      What's the kv that is.
      • itspfo
        • 32
        2000 kv
        • Diegoboy
          • Mar 2007
          • 7444
          thread moved
            If you are running 4S then props between an m445 and m645 would probably be appropriate. In the summer you may need to be careful as high water temps won't cool as well.
            • stadiumyamaha
              • 1371
              I've had great luck with both props fluid mentioned. May also try a x632 or even some of the cheap carbon props until you find a size that works.
