1/8 hydroplane
  • hydroman2112
    • 108
    1/8 hydroplane
    ok heres my info for this boat im using a KB45x77 mm motor from hobbyking it is 1200kv its voltage is 36v highest rated power is 2880w/esc is swordfish240hv/iwant to use 8s/my drive cable 1/4"/prop?/ i have prather270 but i think it will be to much prop/
  • RandyatBBY
    • 3944
    Get a stepped down 1/4 to 3/16th stub shaft and start with a X445 or X447 prop. I sell the shafts if you need one $29.95 plus shipping
    Randy
    BBY Racing
    • hydroman2112
      • 108
      no offense but for 9more dollars i can go to hobbyshop and new cable with stepdown
      • RandyatBBY
        • 3944
        You miss under stood me that was for the whole shaft. But if you have a hobby shop close to you all the better talk to them. no offence taken.
        Randy
        BBY Racing
        • hydroman2112
          • 108
          thanks prop info i will try x447
          • RandyatBBY
            • 3944
            Always start with the smaller prop first to save burnt up ESC.
            Randy
            BBY Racing
            • hydroman2112
              • 108
              ok i will try the x445 first ; thanks
              • RandyatBBY
                • 3944
                Also run the ESC at full throttle it will run cooler. If it is too fast go to a smaller prop until you reach speeds you can handle.
                Randy
                BBY Racing
                • Make-a-Wake
                  FE Rules!
                  • 6057
                  Hi Hyroman.......................if you want no sugar coating here the KB45 is not at all up to the task of powering a 1/8 hull. Especially coupled with a prather 270. I really hope you dont try it cuz my bet is that it will pop the 240a ESC..............that's how inefficient and amp hoggish they are....................that motor is a recipe for disaster in that hull. You need at least a Leopard 5692 in the 1000-1200kv range. Just giving you facts based on my experience
                  • hydroman2112
                    • 108
                    ok i wil not use kb45 i will wait to get a 5692 thanks for telling me
                    • hydroman2112
                      • 108
                      ok i wil not use kb45 i will wait to get a 5692 thanks for telling me was not going to use 270. prop suggested was a x445
                      • hydroman2112
                        • 108
                        what fightercat 5692 1300kv
                          How fast do you want to go? What kind of run time do you expect? If you are running 8S then I'd suggest getting a motor with a Kv between 800 and 950. Using a 1300 Kv motor on 8S virtually guarantees a burned up ESC and damaged cells. And a 45mm prop is really too small for a big 1/8th scale boat; it may or may not even plane off with one. With a good 900 Kv motor and good cells you can run up to an x460 and get speeds in the mid-60s...if the boat is well setup. With budget parts I'm not so sure. Remember you can have cheap, fast or reliable - choose any two.
                          • siberianhusky
                            • Dec 2009
                            • 2206
                            This hobby is so much more fun when you run quality equipment within it's limits, been my experience that the guys who are trying to go fast cheap seem to spend more time waiting for new parts than actually running the boat!
                            I think it costs less to do it right the first time.......in the long run.
