What Prop Single EKOS
  • Norman2
    • Sep 2008
    • 354
    Hi, I bought an EKOS hull from Ebay and have it set up as a single
    UL-1 Motor and ESC 2030 KV
    2 x 2S1P 5000, MAH 40C lipos in series
    Want to use an Octura X640 but think I should start with an X440.
    Any advice on right prop choice. Thanks for any help. I use to run
    this 640 prop with an Ammo 2300 motor and everything was OK. Feel
    that with less KV 640 may be too much.
    Norman2
    34" Ekos Cat UL-1 Powered
  • wht73
    • Feb 2012
    • 113
    I don't know if this will help as I have the same hull but twin 3400kv mtrs.
    I'm running 2-3s paralleled 45/90c and a oct x442's and get 59.2 mph with slight wind and chop.
    I have a spare hull and was thinking of converting it to a single. do you have any pic's of the conversion?
    Thanks
    Chris
    • Norman2
      • Sep 2008
      • 354
      Hi Chris. Here are the photos of the conversion to single, Norman
      • wht73
        • Feb 2012
        • 113
        Thank you. How does it handle with the single?
        Do you have thread that shows the conversion?
        How did you seal up the old stinger holes?
        • Norman2
          • Sep 2008
          • 354
          Chris, I did not create a thread for the conversion because it was pretty simple. Just transferred all the hardware from my 35" scratch built
          cat "Shake N' Bake" which was very successful in LSO but was showing a lot of cracks I couldn't repair. Hull was totally bare of any rails
          etc. Filled the holes from the inside with fiberglass and refinished from the outside with bondo and repainted transom area. I have not tried
          the boat out yet until the weather up in the mountains where I live improves. (windy). I will et you know the results when I do. Regards
          Norman
          PS. attached photo of my Scratch built 35" cat which is now a shelf queen after 13 wins in two seasons in LSO
