another genesis prop question
  • camarohrod
    • Mar 2012
    • 64
    what is the diameter of a genesis shaft? i thought i read somewhere that it was 4mm but i cant find a post about it now. if it is will a 3/16 prop fit it or do i need to go ahead and replace my shaft cause i cant find any 4mm props.
  • h2o 1
    • Sep 2011
    • 854
    The stock Genesis uses a 4mm shaft, u can use 3/16 props with a adapter made of brass tubing. You can buy theses here at OSE or make them yourself.
    • camarohrod
      • Mar 2012
      • 64
      thanks
      • CatMan
        • Jun 2010
        • 96
        I just got my prop adapter from OSE for my genesis and it works great! wanted 3/16 props now for selection, but planning on changing to 3/16 shaft in the future and didnt want to buy props now and again later.
        wanted stronger flexshaft for future upgrades, but now I want one so I won't have to keep pulling motor out just to grease the shaft!
        • camarohrod
          • Mar 2012
          • 64
          i always just pull the piece that holds the prop on the outdrive and then just loosen the shaft from the motor and pull it out that way
          • CatMan
            • Jun 2010
            • 96
            Are you saying unbolt strut height screw and pull that strut piece off, then pull shaft out? I guess 1 bolt would be better than 4 and a motor. boy am i glad i mentioned that.
            I need to grease mine today and will try it that way! I still want to change to 1 piece 3/16th's in the future, mostly because i've read these 2 piece shafts can't handle the power of stronger motors and break.
            but don't know enough yet to do much of anything. just playing with it til something breaks or I figure out and attempt to try something better. right now, still too scared to cut tube out and replace.
            • SirBudman32
              • Aug 2011
              • 701
              I just did my first stuffing tube change and on a Genesis. I bought a hole new strut and rudder with 150- 3/16th's one piece shaft from Ose even game with new stuffing tube and liner. Was like you, scared but after I did it was really easy.
              Modified Jae21, Stock Jae21, Cheetah, Ul-1, Shock Wave 26 V2 (Rescue Boat).
              • CatMan
                • Jun 2010
                • 96
                Thanks SirBudman Looks Good and you make it sound so easy.
                I need to start reading up on that, does the flexshaft come in the length you need it? I've read awhile back about soldering flexshaft then cutting, then I got lost ( and I'm lousy at soldering).
                I'm still trying to figure out what stuffing tube size, then which size liner goes into that. probably scared for no reason. Did you switch to use stronger motor? I have so much to learn
                could you give link or location on the OSE stuff, thanks
                • SirBudman32
                  • Aug 2011
                  • 701
                  Just get the one from here at ose as it comes with everything. Rudder strut flex stuffing tube and liner. I got the 150 cable 24 inch. Yes have to cut the cable but that was easy to just pain to solider.
                  Catamaran Strut and Rudder System
                  In Stock: 5
                  (Enlarge)
                  Inline aluminum rudder and strut system for Catamarans with built in rudder water pickup. Features a nylon break away bolt on the rudder to reduce damage when hit by submerged objects.
                  Mounting plate measures 30mm (1.18") wide x 24mm (.95") tall.
                  Leading edge of the rudder blade measures 87mm (3.42")
                  System Includes the following with two cable options:
                  (1) aluminum rudder
                  (1) aluminum strut with installed 3/16" Lead Teflon Bearing Sleeve.
                  (1) Shrink Tubing.
                  (1) 1'(305mm) piece of 1/4" K&S Brass Tubing.
                  (1) OSE assembled .150"(3.8mm) with 3/16"(.187"/ 4.75mm) propeller shaft or
                  (1) OSE assembled .187"(4.75mm) with 3/16"(.187"/ 4.75mm) propeller shaft.
                  Requires:
                  Requires customer to cut flex cable to required length.
                  Du-Bro 489 or 490 steering linkage connectors.
                  489 is for 2-56 linkage rod, 490 is much stronger 4-40 linkage rod but will require drilling the the hole larger on the steering arm.
                  Note: This is the second revision of this item. As of 10/25/2011, we have upgraded the strut to allow use with a larger prop and strengthened the strut barrel.
                  cable diameter: .150 cable 24" long
                  .187 cable 18" long (+$15.00)
                  • CatMan
                    • Jun 2010
                    • 96
                    Thanks very much, one more question if i could....How do you decide between .150 and .187 ? 187 just stronger? just bigger? does it make much difference?
                    I keep hoping that eventually I'll get better at soldering and it looks like these boats will make a solder-er out of you, whether you like it or not.
                    and it did get better once i figured out a 25watt iron doesn't do 10ga. wire. I hope my next post with pics isn't asking how to fix a golf ball size hole in my hull.
                    • SirBudman32
                      • Aug 2011
                      • 701
                      After doing alot or reading it seemed to be the normal to use the 150-3/16ths.
                      • CatMan
                        • Jun 2010
                        • 96
                        thanks for the help. I will be doing that soon.
                        • CatMan
                          • Jun 2010
                          • 96
                          Hey Camerohrod what prop(s) are you going to try? I finally gps'd mine today for speed difference on the 2 props I have
                          1st prop: 38mm diameter (1.49 inches) 53mm pitch (2.08 inches) Sharpened and balanced, ready to use. 3/16 bore. from zippkits on ebay Top speed: 40.1mph
                          2nd prop: Octura X442 from OSE. straight from the bag. not balanced, sharpened or anything. Top speed: 40.8mph
                          Stock motor, T180A esc, 2 - 2S 4000 Mah 30 to 40C lipo in series.
                          • pitstopme2
                            • May 2012
                            • 1
                            Hi Guys,
                            Ive just joined OSE forum and started reading your posts you guys ask and answer all the right questions. i appreciate your dedication and helpvery much i have a spartan new on 6s and now i am hooked on r/c speed boats so i aquired a genesis and i am hoping to get it running in the 80's mph range. so i have been doing a lot of reading on the do's and don'ts and i am getting there. But if you guys have any tips for me i would apprecciate all input. i bought the castle 240 esc and the 4082 leopard 1500kv motor already for my hull and reading up just now on the post i have recently added the 150 3/16 catamran rudder system to the list. are there any other suggestions to get me to my goal...
