Prop For Catamaran
  • steamboatbob
    • Jan 2010
    • 51
    Prop For Catamaran
    Hi
    I need a little help here guys as im not sure if this is a prop selection question or not
    I have an R2 Godspeed cat running the following
    Leopard 4074 2200KV motor
    turnigy 180AMP esc
    3/16 driveline
    runs on 4S, 2*2S 40C 5000mah zippy batteries
    i have a X440(3) that works very well with this setup low temps on all hardware, but i have previously run the same setup with an X445 in a rigger and very low temps, just recently i got a X445 and an M545 to test on my hull but when it came down to exiting a corner with both of these props the esc cut the power to come in. so i guess im asking if i am over proping the setup, the other thing i need to mention in my static balancing the props seem fine but when on the test bench the seem to be a small vibration with both of my new props but not with the 3 blade.
    the temps could not be measured properly as i only get a few laps before it cut out on me with the new props
    can someone please shed some light as to what is going on
    video here of the 3 blade
    My budget on boats depends on how much money the wife dosent know i have
  • Diesel6401
    Memento Vivere
    • 4391
    Double post....
    - Diesel's Youtube
    - Diesel's Fleet
    • Diesel6401
      Memento Vivere
      • 4391
      Your batteries aren't up to the task. The motor is pulling more amps then your 4s setup can deliver. Good way to fry a motor or esc. If you went 4s2p it would work. I run a m645 on that motor in a 32" mono running mid 50s! But she's a hot setup that way. I prop down in the summertime, but in the winter I can get away with the m645. The seakings also have a very senstive lvc, if set in *auto detect* you'll typically have the lvc pre-maturely cutting in. Manually enter 4s into the programming and 3.0v per. Hopefully that makes sense.
      Sent from my T-Mobile G2 using Tapatalk
      - Diesel's Youtube
      - Diesel's Fleet
      • steamboatbob
        • Jan 2010
        • 51
        yes it makes perfect sense, so stear clear of the m545 for me untill winter, and bring out the program card for the esc
        i have preset the esc to 4s but let the Low volt at factory settings as i didnt wish for the lipos to go too far and i have had everyone i know tell me different values as to put the lvc at so i left it high to be able to be 100% sure of no battery failure, and srry bout double post i have a very slow computer and it is easy to double post on forums.
        but thank you diesel for your input
        • Diesel6401
          Memento Vivere
          • 4391
          You can run the m545 if you go to a 2p setup, but be very careful with it and keep the runtime very low.
          - Diesel's Youtube
          - Diesel's Fleet
          • TheShaughnessy
            • 1461
            Sure the lvc isn't perfect but i think it does have ALOT to do with batteries. If they are starting to puff... they arn't putting out near what they are rated for anymore. Ask me how i know.
