Prop Question
  • Fastfish
    • Mar 2012
    • 34
    Prop Question
    Hey guy's I'm new to the rc boat world. I can't wait to get my Genesis in the water. It came in the mail today. I've seen in video that the original prop will not hold up. I ordered a 442 balanced and polished prop. My question is...The new prop looks to be the opposite of the original prop. Can the motor be wired to run opposite to be able to run the new prop?
  • bozo586
    • Aug 2009
    • 344
    pull one wire on motor,switch it with another one on esc and connect remaining loose wires together-motor should run reversed with no harm done.
    • bikenewby
      • 42
      The stock flex cable is for counter-clockwise spinning. Running it reversed will cause a problem.
      • martin
        • 2881
        You cant run the other way as youll unravell the flex shaft.
        • sanyijr
          • 377
          Fastfish,
          I don't think it was made cler enough.(in case you skim the text) The motor can be run either rotation by switching any two motor leads. BUT the flexshaft CANNOT be reversed. They are a wound coil. If you look at it, they are wound in one direction like rope. And if you reverse the rotation direction, it will unwind and expand inside the brass tubing and cause massive damage! It could lead to fried motor, esc and majot boat damage. So you need to either (1) get the correct rotation prop or (2) get the flexshaft that has the correct rotation to match the new prop.
          And if you are thinking about it... Don't. Don't even try it.
          • Fastfish
            • Mar 2012
            • 34
            Thank you! I understand...I will get a new prop. I will run the plastic one that came with the boat till the new prop comes in...Thanks again!
            • bozo586
              • Aug 2009
              • 344
              fastfish-they are right,i didn't think about the flex cable change,i dropped the ball on this one sorry and glad they jumped in,thanks guys!
              • TheShaughnessy
                • 1461
                u must have ordered a 442r i made that mistake when i started out, thought the r ment racing and not right hand
                • Old Sloppy
                  Harry from Atlanta
                  • Jul 2007
                  • 201
                  The good news is now you can start a "counter rotating twin cat" project.
                  Harry
                  60" Expresscraft SuperCat
                  (2) 2028 Castle motors 64.7 mph
                  10s3p with x450/3 props
                  15,000 mah 40c cells,
                  • Fastfish
                    • Mar 2012
                    • 34
                    yep! LOL
                    • Fastfish
                      • Mar 2012
                      • 34
                      Guy's thanks for your help...One more question, can someone point me in the right direction for buy a new flex cable to match the right handed 442 prop I bought. I looks like its cheaper to buy a flex cable than a new prop.
                      • egneg
                        • 4759
                        I would PM or email FighterCat57. I am sure he can help you out with what you need.
                        IMPBA 20481S D-12
