hydro talk
  • steveo
    • 1595
    hydro talk
    tried looking in to the search section but did not find much
    - how do i know which props are lifting type and when to use them
    - i have seen photos of hydros with a negative angle on the strut is this to pick up the rear of the boat- why not use a lifting prop
    - if you had a long strut on the boat would you not need a lifting prop or any angle because it would be easier to lift up because of leverage and less likely to blow over by making the boat feel longer
  • Boaterguy
    • 1779
    http://forums.offshoreelectrics.com/...ions-somewhere.......
    I don't know the strut angle vs lifting prop, but a lifting prop is less efficient then a normal prop so minimal angle with less effect than a lifting prop would be more efficient.
    • steveo
      • 1595
      good find thanks
