You think these props would be to big.
  • floatn turd
    • Oct 2011
    • 267
    What do yo think of these props for the following set-up?
    MOTOR: TP 4050 1160kv
    ESC: 2s-8s 240amp by fightercat
    HUll: Motley Crew
    Props: Prather SS Prop S-255
    Prather SS Prop S-260
    Octura 2 blade prop X572
    Octura 3 blade prop X670
    You think they are too "big" for that set-up?
    thanks
  • Chilli
    • 3067
    I'm not familiar with that motor and don't know what batteries you'll be running but 70+mm props are WAY big for that size hull. You usually find them in 45 inch gas boats. My guess is the boat would handle terribly. Plus those props are only made for 1/4 inch prop shafts. You'll want the RPM about 30k unloaded (+/- a couple hundred) and a prop size in the 40's
    Mike Chirillo
    www.capitolrcmodelboats.com
    • Make-a-Wake
      FE Rules!
      • 5554
      Yes, too big.
      • floatn turd
        • Oct 2011
        • 267
        Perfect, thanks for the response guys.
