prop nut help?
  • Mattwarner
    • Aug 2011
    • 495
    prop nut help?
    My first FE build is finally ready for its maiden voyage, but when bench testing the prop nut (bullet style) keeps spinning off? the rotation of the prop is counter clockwise looking from the back of the boat which i understand is correct, what should i do should i loctite it on? Ive read of people using some fuel hose but that doesnt seem secure to me?
  • siberianhusky
    • Dec 2009
    • 2206
    Keep the bullet for display or toss it in the pond! Use a Zuber nut or nylon lock nut, yes fuel tube does work but I don't do it. Guys have been doing it for years.
    The nut might not look as cool but I'd rather keep my props. No difference in performance in the thrashed water right behind the prop.
    • Diegoboy
      • Mar 2007
      • 7444
      thread moved
      • Mattwarner
        • Aug 2011
        • 495
        Thanks, think I will grab myself some stainless nylocs and ditch the bullet
          I'm with siberian on this.The bullit nuts suck.Somehow,I put one on recently and almost lost a prop because a bit of weeds caught up.There are locking nuts in the store somewhere that are great.
          • Boaterguy
            • 1779
            if you reallywant the bullet you can use the locking nuts and a bullet nut behind
            • pyroM!KE
              • Jan 2011
              • 379
              I use blue loctite on my bullet nut and it works great..Even when you break the nut loose the loctite keeps the nut on there pretty good..You have to turn it off with a wrench a couple turns before you can hand loosen it..
              I trust the blue loctite on my big heli's and I trust it on the bullet..Just be sure you let it set overnight to cure..
              • Drax21
                • Jul 2011
                • 1077
                Like Mike ... I use Loctite and even it the past I have used 181 super glue. Haven't had a Bullet nut come loose. I will say Kintec supplied me with a 187 with soldered end and zuber nut but it mysteriously fell off taking my new prop with it. I never did check if the zuber nut was tight though.
                • Mattwarner
                  • Aug 2011
                  • 495
                  I may have to use the loctite solution for the time being as getting a 3/16 nyloc nut in the UK is proving difficult!!
                  Does anyone know the thread pitch on a 3/16 flex? (ive been told its a choice of either BSF/UNC or UNF???)
                  • Drax21
                    • Jul 2011
                    • 1077
                    Have you checked Astec? They sell Nyloc Nuts.
                    • Mattwarner
                      • Aug 2011
                      • 495
                      They only have Metric sizes on their site
                      • egneg
                        • 4759
                        I believe it's 10-32
                        IMPBA 20481S D-12
                        • Mattwarner
                          • Aug 2011
                          • 495
                          thanks! I am going to take a punt on these for the sake of a few £
                          • pyroM!KE
                            • Jan 2011
                            • 379
                            Yes it is 10-32..
                            • Drax21
                              • Jul 2011
                              • 1077
                              Astec sells them super cheap.
