UL-1 stock prop breakin
  • hobby_man
    • Sep 2011
    • 125
    why do I keep breaking my prop? 3x now
    I just got 1 run on a new 3 stock 3 blade prop.
    If I run it to high with regards to the boats water line will it break?
    I have hit nothing.
    will caveating cause it to break?
  • sanyijr
    • 377
    My guess if because its stock? You have lots of debis in the water?
    Check out the UL-1 section for good metal upgrades..... Grims, octuras and alike.
    • hobby_man
      • Sep 2011
      • 125
      nope, just fish
      he boat is off the shelf stock, 1 prop lasted for 12 runs, I went through 3 props today in 4 runs
      • dana
        • Mar 2010
        • 3660
        Did you leave the little piece of silicone tube on there?
        • hobby_man
          • Sep 2011
          • 125
          UH I did not see any tube on the prop
          should their be?
          • dana
            • Mar 2010
            • 3660
            There is supposed to be a small piece of the blue cooling tube between the prop and the nut that holds the prop on. If you tighten the nut on too tight it cause tiny hairline cracks in the plastic prop not visible to the eye. Then under load the cracks cause the prop to break. Try putting the nut on and just barely snug it to the prop. You will be good to go
            • hobby_man
              • Sep 2011
              • 125
              interesting, this must be the problem, carbon fiber is real brittle, I was careful to stop the lock nut right at the point of tangency.
              now if I had another prop!
              • dana
                • Mar 2010
                • 3660
                Well it's just my guess based on my experiences with plastic props. Those plastic props are 20 bux for two, for and xtra 10 bux you could get a nice sharpened balanced x440 copper prop. Much better and won't snap blades off
                • hobby_man
                  • Sep 2011
                  • 125
                  $10 where? OSE sells them for 38 and they are out of stock.
                  • dana
                    • Mar 2010
                    • 3660
                    I said xtra 10... On top of 20. Guess I was a little off. I can sell you one all finished for 32 bux shipped if you like
                    • hobby_man
                      • Sep 2011
                      • 125
                      yes you did type extra, I'm bad
                      what do you think of this prop for my UL-1, I just back into boats ater being out of Nitro boats for 15 years, I went all electric this time and I have a drawer full of maybe this prop will work better, trying to avoid a repeat, no user groups back then LOL
                      GrimRacer L40x57 Lifter Metal Boat Propeller from AquaCraft
                      • dana
                        • Mar 2010
                        • 3660
                        The l40/57 is the best prop for ul1. I use it. Has to be balanced and sharpened extremely well for it to work
                        • dana
                          • Mar 2010
                          • 3660
                          More prop work. If your boat is stock motor/esc and you got 56 it's mind boggling.... What gives?
                          • dana
                            • Mar 2010
                            • 3660
                            It's unbelievable fast. Nobody I know of has gps a stock ul1 at over 55, and that's a stretch. Your gps maybe giving false readings. Most using that prop report between 48-51 mph
                            • dana
                              • Mar 2010
                              • 3660
                              Yeah, well I'm not convinced, unless someone else can chime in and verify that those speeds are possible on stock setup.
