Prop up my Titan 29?
  • Bigbore
    • 179
    This is my present setup and I feel it perfect to run the boat in the open sea when the water is very calm and there are only few chops.
    Motor: Leopard 4082 1600Kv
    ESC: Hobbywing Seaking 180A-R
    Timing: 15°
    Battery: Zippy 5000mAh 40C 5S2P
    COG@ 30%
    Prop: X440/3
    Run time: 5 min
    ESC Caps: 49°C 120F
    ESC Temp: 42°C 107F
    Motor Temp: 38°C 100F
    Zippy: 52°C 125F
    Vmax= 71,1Km/h 44mph
    Prop:M445
    Run time: 5 min
    ESC Caps: 55°C 131F
    Etti Caps: 44°C 111F
    ESC Temp: 49°C 120F
    Motor Temp: 42°C 107F
    Zippy: 48°C 118F
    Vmax= 72,7 Km/h 44,8 mph
    I prefer M445 because it provides faster aceleration.
    I was told M props are like the X but with out the tung and this makes a little more slip at low speeds and then higher speeds at top speed.
    What prop should I try to reach 50mph at the pond with mirror water?
    Same diameter and bigger pitch (X645)?
    Or same pitch and bigger diameter (M447)?
  • Make-a-Wake
    FE Rules!
    • 6057
    Try an x642 or an s220.
    • Bigbore
      • 179
      Thank you for your advice.
      So, no more than 45mm prop on this boat?
      • Make-a-Wake
        FE Rules!
        • 6057
        You'll get into some torque roll issues if you go much bigger diameter
        • dana
          • Mar 2010
          • 3660
          Wake is right. Bigger prop= torque roll. X642 for your motor. I run 3674 1700kv on 5s with x444 and get consistent 49mph
          • Bigbore
            • 179
            This morning at the pond on mirror water I had the fastest and hottest run ever with this Leopard 4082 1600Kv
            I was able to run full throttle always ... while turning too and the Zippys went at LVC in 3,5 minutes and these were the temps still with M445 Prop:
            ESC Caps: 56°C = 133F
            Etti Caps: 44°C = 111F
            ESC Temp: 51°C = 124F
            Motor Temp: 51°C = 124F
            Zippy: 60°C = 140F
            Top speed was 78Km/h = 48,5mph
            I read that 140F is the hottest temp for ESC and motor.
            Am I cooking the batteries?
            What are your suggestions? Can I prop up without ??
